Thanks Steve for the support. I´ll send you an email once I take a decision. I talked today to the quaife people and got quoted 595+vat for a ATB Helical LSD. If you could post the quote for a gripper diff that would be great, otherwise an email is perfect.
cptkirk I read the hole thing some months ago and are aware of other handling issues on these types of minis. It is a very difficult set up to tune as short base + weight on the back + big power and torque is not a great combination.
On the other side the N10 Mini which has a hayabusa engine in it handles like a dream being a 100% neutral and very very predictable on the dry. You can play with the steering in each corner and find the perfect sliding spot to get through the corner. Bit unstable at high speeds (+100mph) but that is predictable from a shoebox aerodynamic shell.
On the Volvo Mini I´m finding the effect you have already described as driving on its tip toes and it´s very very sensitive to the steering wheel input with a std. steering rack. The car was laser aligned last week but I would like to double check the front and the rear axels are aligned and each wheel is sitting at its correct spot. (I presume the values might be correct for the machine but the wheel might be displaced). Any advice on how to double check this at home?
I would also like to gain more drop on the suspension as I feel like the wheels might be lifting when driving up the mountains. How can I gain drop on the coilovers?
Cheers,
Gonzo
