Sorting Out Body Work Rust W/out Too Much Damage!
Posted 30 July 2013 - 11:57 AM
Posted 30 July 2013 - 12:05 PM
Front or back? is it very bad or just surface rust? Give the areas a good wire brush/sand to get rid of the rust, If it's not too bad, mask off the area and give it a coat of primer and paint. If it creates a hole then it will need to be welded, then repainted.
Posted 30 July 2013 - 12:59 PM
Edited by samt88, 30 July 2013 - 01:00 PM.
Posted 30 July 2013 - 03:31 PM
Posted 30 July 2013 - 03:39 PM
All the photos are here: http://www.theminifo...blue-valuation/
There is some good advice on there already from AVV IT amongst others. A panel is needed, rear quarter needs checking, you may get away with it you may not. Front end needs looking at before it gets too bad.
Posted 30 July 2013 - 03:48 PM
The rear quarters certainly the right hand one, the l/h might be saved. The A panels are shot and need replacing. The front panel is crusty as well so that will need to be replaced as well.
The A panel damage will have spread to the A post flange the A panel wraps around so some more work there.
Sorry not what you want to hear but better to be honest rather than just say grind it back it will be ok, it won't.
Posted 30 July 2013 - 10:08 PM
Posted 30 July 2013 - 10:40 PM
The car will no doubt look quite scabby in 11 months time but there is not much you can really do without disturbing the paintwork.
Also tagged with one or more of these keywords: rust repair
Mini Technical Sections →
Bodywork, Paint and Detailing →
Wheel Arch Repair For MotStarted by adman020 , 21 Jun 2024 ![]() |
Non- Genuine Door HingesStarted by CBJ805T , 09 Jun 2024 ![]() |
Where To Start - Rear EndStarted by OzKopite , 03 Mar 2024 ![]() |
Mini Specialist For Welding -South East/south WestStarted by s2ulk , 20 Oct 2023 ![]() |
Wheel Arch/boot Floor Repair HelpStarted by austinmayfair85 , 10 Aug 2023 ![]() |
