Centre Speedo
Jimmyarm
, May 09 2006 10:40 AM
13 replies to this topic
Posted 09 May 2006 - 10:40 AM
Hi All,
Does anybody know if the wiring (for the fuel gauge) and the speedo cable from an 89 City (two clock dash) will work with an older style centre speedo i.e a straight swap ?
Am putting a dash together and quite like the idea of having the big speedo in the centre and then just the tacho behind the wheel And it fits with all the other gauges I now have as its by Smiths
Jimmy
Jimmy
Posted 09 May 2006 - 10:58 AM
you will need to get a new speedo cable because the end is different, and i am sure you can get an adaption to the wireing that you can just plug in.
if you want to fit the centre speedo you will have to consider the sound deadning and the trim because all that is different too
do you have a top dash rail?? that will need to be removed so you can actually see the dials, otherwise they would be hidden.
hope that is some help.
Posted 09 May 2006 - 11:00 AM
The wiring from the later loom can be adapted to fit the earlier centre speedo. I've got an 80s Loom in my old Mini. The wiring colour codes are the same so it's not too tricky to adapt.
Posted 09 May 2006 - 11:05 AM
bah beat me to it. but yeah to second the above. you CAN get conversion looms but i dont think you NEED one. It just makes things a bit quicker that's all.
Posted 09 May 2006 - 12:10 PM
Sod the conversion loom I'll bodge it Dont want any of the lights to work in it, will be putting new ones on the dash. Will have a look round for the cable converters.
I'm keeping the top dash rail in and mounting the centre speedo in the mdf/plywood dash that I will put between the two rails so It wont be a problem seeing it.
Hadn't seen one done like that before and was messing about at the weekend and thought it would look pretty cool, and its nice and shiney
Jimmy
Jimmy
Posted 09 May 2006 - 06:33 PM
Then you'll need an extra long centre speedo cable, the standard one has no slack and will only allow the speedo to fit in the standard position.
You must have the lights working in it, how will you see it at night if you don't? Use the conversion loom, it's easy.
Posted 10 May 2006 - 08:18 AM
Or you can buy one of the five different lengths available from Mini Specialists such as Mini Spares which are designed for this modification.
Posted 10 May 2006 - 09:52 AM
When I said the lights I meant the ignition, beam, indicator etc not the light so I can see it !
Will take the two clocks out at the weekend and have a nose around
Thanks guys
Jimmy
Thanks guys
Jimmy
Posted 10 May 2006 - 12:41 PM
I guessed that much, my point is that you will need the dial illumination lights working. These things don't have re-wireable lamp holders so you'll need to buy the conversion loom to get hold of lampholders for the lighting. I don't think you can get the holders for this gauge on their own, even from the kit car type wiring companies.
Posted 10 May 2006 - 08:06 PM
iv just put mine in with the top dash rail and i can see it fine!
it may be because i sit lower down in my classic bucket seats!?
the only proplem i have with it is the fuel gauge is a bit wierd!
it reads fine when im ideling but as soon as i move along it drops down to half what it should! not sure why any ideas?
i used the wiering loom from minispares mainly for the bulp holders etc!
cheers
josh
cheers
josh
Posted 11 May 2006 - 10:32 AM
I think that is to do with the resistance (ohms) range of the sender unit in the tank. It will be different from what that gauge is supposed to use ? If so you just need an old working sender that is designed for the centre gauge ?
Might be wrong though !
Jimmy
Jimmy
Posted 11 May 2006 - 12:39 PM
I believe the tank sender is the same (SPi and later were different, but only in they had extra filters, pumps & things). Sounds like an issue with the voltage stabiliser, but not having my wiring diagrams close, I can't say for sure if it will have a bearing on it. I'll have to check later.
