How Do I Know If My Shock Absorber Is Okay?
suspension
2 replies to this topic
#1 joey weston
joey weston
  • 15 posts
Posted 04 August 2013 - 10:44 PM
Hi there, i've been doing a light rebuild of my mini and am in the process of stripping the rear sub-frame, when i took the rear shock off, it can be pushed fully in by hand and then dosen't seem to come back too easily. Is this normal for a mini? With it being on cones i'm not sure, haven't took the other side off for comparison yet. Any advice would be much appreciated!
Thanks Joe.
#2 Frisco
Frisco
  • 414 posts
Posted 04 August 2013 - 11:09 PM
There is nothing special about mini shocks so it should act like any normal shock.
Oil filled - It should be stiff to push back and pull out and should stay where it's left.
Gas Filled -  It should be stiff to push back and should push itself out when you let it go.
Neither should leak
#3 joey weston
joey weston
  • 15 posts
Posted 05 August 2013 - 09:40 PM
Okay great thanks!
Also tagged with one or more of these keywords: suspension
