Will Mk1 Xr2 Pepperpots Fit A Mini?
22 replies to this topic
#1 MINI MAD RKH
MINI MAD RKH
  • 308 posts
  • Local Club: DCMOC
Posted 06 August 2013 - 01:18 PM
as title
they're 13 x 6.5J & I don't know the offset
they don't appear to have much of a dish
failing that info, what are the usual offsets used for 13 x 6.5'' Mini wheels??
Thanks :D
#2 Tupers
Tupers
  • 4,173 posts
Posted 06 August 2013 - 01:23 PM
They're a different PDC to a Mini so wont fit on the studs.
The Fiesta has a 4x108MM pattern but a Mini is 4x4 inches.
#3 MINI MAD RKH
MINI MAD RKH
  • 308 posts
  • Local Club: DCMOC
Posted 06 August 2013 - 01:32 PM
Great, thanks for the speedy reply :D what wheel is that, in yr avatar?
& GRRRRRRGH that they won't fit :lol:
Edited by MINI MAD RKH, 06 August 2013 - 01:33 PM.
#4 Mini-Mad-Craig
Posted 06 August 2013 - 01:44 PM
-7 is the usual offset for a wide 13, you could make them fit with a little work.
Redrilling the wheels, you could redrill the hubs also, but I wouldn't want to do this with the way the Mini suspension and hub works.  You could also see what the difference is between Xr2 rear drums and hubs, and see how easy they will be to change, that won't be a lot of work. The fronts would be slightly harder, but you could get some 101.6mm to 108mm adapters made up, but they'd stick out quite far then depending on offset.
If you want them enough...
you can make it happen
Edited by Mini-Mad-Craig, 06 August 2013 - 01:45 PM.
#5 scotty_1987
scotty_1987
  • 874 posts
  • Local Club: MiniBallers
Posted 06 August 2013 - 02:14 PM
Hell Yes! what Craig said, if you want them enough, you'll find a way, you'll find a way!  :highfive:
#6 MINI MAD RKH
MINI MAD RKH
  • 308 posts
  • Local Club: DCMOC
Posted 06 August 2013 - 04:30 PM
Yeah, I was thinking that as the difference is only about 4mm
so, the companies that make hubs, they'd be able to do a bespoke pcd, Shirley? :D
I'm not sure if they'd even look right, maybe time for a photoshoppe  :thumbsup:
Edited by MINI MAD RKH, 06 August 2013 - 04:31 PM.
#7 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 06 August 2013 - 04:36 PM
Having owned several xr2 pepper pots, I'm sure that there isn't enough meat to redrill the wheels, so the only option is to fit fiesta calipers? Then graft the rear hubs on somehow
#8 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 06 August 2013 - 04:45 PM
Adaptors
#9 MINI MAD RKH
MINI MAD RKH
  • 308 posts
  • Local Club: DCMOC
Posted 06 August 2013 - 05:19 PM
Do Ultralite make adaptors for the Mini? Or rather, who makes them? :D
Edited by MINI MAD RKH, 06 August 2013 - 05:21 PM.
#10 Mini 360
Mini 360
  • 4,933 posts
Posted 06 August 2013 - 05:27 PM
Just google what PCD to what PCD you require.  Then buy them and fit them.  :highfive:
#11 MINI MAD RKH
MINI MAD RKH
  • 308 posts
  • Local Club: DCMOC
Posted 06 August 2013 - 05:50 PM
Yeah, just thought of that :D thanks
I shouldn't really be buying wheels, I have 4 1/2 spare sets already, should sell some others 1st :lol:
so I searched for 4x4'' to 4x108 & it's only giving me listings for 4x100, not the full 4x101.6
http://www.ebay.co.u...x108mm&_sacat=0
so, custom ones then?
http://www.ebay.co.u...=item27d39197b5
will have to ring them, see if they can do 4x101.6
Edited by MINI MAD RKH, 06 August 2013 - 05:59 PM.
#12 scaffers
scaffers
  • 476 posts
Posted 06 August 2013 - 06:01 PM
I've seen the very early XR3 cloverleaf alloys fitted to a mini 25+ years ago.
#13 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 06 August 2013 - 06:07 PM
Everything is possible with a mix of time, experience and money, a lot of one means you need less of the others :-)
#14 MINI MAD RKH
MINI MAD RKH
  • 308 posts
  • Local Club: DCMOC
Posted 06 August 2013 - 06:17 PM
Yeah, I have some time, a bit of experience & a maths-head (but no idea about material, no lathe & accurate drilling bench) & can't really justify spending all of that money buying adaptors :(
I think I'll try Photoshoppe 1st  :D
#15 jenbachertech
jenbachertech
  • 71 posts
Posted 06 August 2013 - 09:08 PM
Er wouldn't want to spoil the illusion, but.....
If you use an adaptor, you space the centreline of the wheel away from the centreline of the bearings, this then loads the wheel bearings and causes premature failure, poor handling, tyre wear, and all sorts of other issues.
You could get the flanges and hubs redrilled, or bespoke items made, then modify the wheels to allow for the correct offset, but this is a lot of work (and expense) to get a set of ford wheels onto a BL car
it would probably work out cheaper to buy a set of wheels designed to fit.
