Steering Is Messed Up! Maybe Bent Tie Rod?
27 replies to this topic
#16 Yoshii
Yoshii
  • 209 posts
Posted 10 August 2013 - 05:06 PM
Ive bought a jack and axle stands, im hoping to borrow a torque wrench.
Worst comes to worst ill have to buy one, hopefully not as i haven't got too much money.
Attached File  part 1.jpg   58.43K   11 downloads
Attached File  part 2.jpg   72.89K   14 downloads
Right, just thought id upload these as i was sorting out another problem with my car and noticed this.
i reversed and pulled up and the wheel were like they were in picture one, then i turned the steering wheel to the middle and picture 2 is the result..
Is this a symptom of the tracking and tie rod problem and will sorting that out sort this out? Or is this another problem?
#17 Yoda
Yoda
  • 1,958 posts
Posted 11 August 2013 - 05:49 AM
Ok, it looks like you have a couple of minor issues here causing your problems,
The bent tie rods will affect two things that you need to be concerned with and that is caster and tracking. It appears that you have a low set up and this will affect camber and tracking and it looks like the tracking has not been adjusted to suit this. also you say that the car pulls to the right. this may mean that one tie bar is more bent than the other and this will affect caster and centre.
My suggestion here would be to first install new tie bars, then get the steering centred and finally get the tracking done.
To centre the steering rack, lift the carpet in the passenger footwell and you should find a rubber grommet on the toeboard. pull this out and you should see a plastic cap that you can unscrew to reveal the inner shaft of the steering rack. move the steering left and right slowly and you should find a hole that a small pin punch or drill bit will drop into. once this is found and centred in the plug hole, if the steering wheel is not in the correct place then remove and rotate it until it is and refit. Now you know the rack is centred.
Unless you have the correct tracking equipment, the next stage is to go to a garage and have the tracking done. If the garage do it and the steering wheel is not centred, make them do it again until it is.
all this should get your steering good to go and will hopefully solve your issues, If the steering is still pulling one way, suspect binding front brakes or a bent rear radius arm.
Hope this helps.
I am sure someone will add their comment here too.
Edited by Yoda, 11 August 2013 - 05:51 AM.
#18 Yoshii
Yoshii
  • 209 posts
Posted 11 August 2013 - 01:23 PM
Thanks for that, I'll wait till I get the tie rods fitter then sort this
#19 Yoshii
Yoshii
  • 209 posts
Posted 12 August 2013 - 02:46 PM
If you dont know how to set Caster, use the standard rods, not adjustable ones or you will find things will be worse. You will need to buy two.
http://www.minispare...92.aspx|Back to
I tried to take yodas advice and get the non adjustable ones, I called up mini spares they don't have them in nor is there any due in. So he advised me to get the ones I initially looked at, I told him id call him back.
With these adjustable ones if i fit them and don't adjust them, will they be okay? Most websites seem to stock only adjustable ones
My plan is to fit these, sort the steering then get the tracking done
Does anyone have any advice?
#20 Yoda
Yoda
  • 1,958 posts
Posted 12 August 2013 - 03:01 PM
All I can suggest to start with is to remove the straightest one you have at the moment and get it as straight as possible. Then match the length to the new ones and fit them and hope they are both EXACTLY the same. Then get the centred rack and tracking done and see how it feels.
#21 Yoshii
Yoshii
  • 209 posts
Posted 12 August 2013 - 03:08 PM
Thanks Yoda, think i might have found something though!
http://www.ebay.co.u...=item3a839ed978
Thats what I need right?
Sorry if I dont know much, Im trying to learn as much as i can  :shy:
Edited by Yoshii, 12 August 2013 - 03:09 PM.
#22 A-Cell
A-Cell
  • 1,610 posts
Posted 12 August 2013 - 03:10 PM
Standard tie rod length 365mm from centre line of hole (attachment to bottom arm) and inside face of welded on washer that the bushes fit against.
Make sure you fit the correct 5/16 bolt and the cup and heavy duty washers.
All the parts you need are in this kit from Minispares http://www.minispare...ic/21A1092.aspx
Get car to garage and ask them to check caster angles and front wheel alignment.
3 to 3.5 degrees caster and 1/16 to 1/8 toe out.
#23 A-Cell
A-Cell
  • 1,610 posts
Posted 12 August 2013 - 03:15 PM
Don't be sorry.
The adjustable ones fromMinispares are much stronger than the standard ones so you won't have the problem again. And they are 10p cheaper. Plus Minispares quality is usually better. Don't mess around with safety critical components. Mini spares are good.
Edited by A-Cell, 12 August 2013 - 03:16 PM.
#24 Yoshii
Yoshii
  • 209 posts
Posted 12 August 2013 - 03:18 PM
I assume the place that I am planning on taking my car to for tracking will know all about the caster and toe out?
#25 A-Cell
A-Cell
  • 1,610 posts
Posted 12 August 2013 - 03:28 PM
If not don't go there. This is basic stuff for the Automotive trade.
The one I use is Stratford Tyres, they use a laser alignment rig, Jim is first rate. Not that far from you really.
http://www.stratford...o.uk/laser.html
#26 Yoshii
Yoshii
  • 209 posts
Posted 12 August 2013 - 03:37 PM
Ive emailed them now, they should get back to me today or tomorrow.
The place I am looking to use is http://www.chemix-autocentres.co.uk/
#27 A-Cell
A-Cell
  • 1,610 posts
Posted 12 August 2013 - 03:42 PM
Looking at the website should be good, they have the right equipment. Hunter laser alignment. Depends how good there operator is!
http://www.chemix-au...co.uk/alignment
Good luck
#28 Yoshii
Yoshii
  • 209 posts
Posted 12 August 2013 - 03:52 PM
Hopefully he is amazing.
I just want  my mini sorted and on the road for me to enjoy :)
