Bogging Down Under Acceleration
Posted 09 August 2013 - 09:09 PM
Posted 09 August 2013 - 09:24 PM
Check for air leaks first
Did you check that the flanges are the same thickness?
Posted 09 August 2013 - 09:29 PM
Dashpot Oil - has it got any?
be my first point of call.
Posted 09 August 2013 - 09:34 PM
Posted 09 August 2013 - 09:36 PM
Have you changed the air filter? I had a cone filter on mine and was sucking in to much air which then made it bog down.
Edited by alex-95, 09 August 2013 - 09:36 PM.
Posted 09 August 2013 - 09:39 PM
Posted 09 August 2013 - 10:00 PM
Flanges are the same thickness, there's oil in the dash pot, like jaydee says I personally think it'll be air leak, but wanting other options. Thanks a lot folks, keep em coming.
Timing needs more advance could be another option.
Posted 09 August 2013 - 10:33 PM
If you increase the efficiency of the inlet and the exhaust its most likely running a bit weak now, have you checked the CO? set to 3% at idle and retest and if its has flat spots then look at changing the needle
Posted 09 August 2013 - 11:37 PM
I replaced the gaskets that I considered knackered,
DId this include the exhaust manifold gasket ? If not this will be your problem.........
Posted 10 August 2013 - 01:15 AM
did you replace the jet, you've pretty much fitted a stage 1 kit !!
Posted 10 August 2013 - 04:15 AM
You can never have too much air, rather not enough fuel to go with the air that you do have.
Posted 10 August 2013 - 07:39 AM
Cheers, Ben.
Posted 10 August 2013 - 08:04 AM
It had to much air then! You could hear the air being sucked in, I added some tape over the filter which then cured the problem. I now have a standard air filter with a few holes, which makes the car run alot better.
Posted 10 August 2013 - 08:10 AM
I'd sort the mixture though , better to match the needle to the air than match the air to the needle. otherwise you have a restricted car.
Posted 10 August 2013 - 08:32 AM
The air is supposed to get sucked in....that's why you or someone purchased a low restriction filter...
As for taping up holes that's not really a solution......it's about the same as pulling the choke out a bit (in fact that would have been better on an SU than taping up the airfilter).
Take the analogy like this....next time you bog blocks up....it's not really blocked....just too much water in the flush...
Edited by Captain Mainwaring, 10 August 2013 - 08:34 AM.
