Switched Live Power In Boot?
20 replies to this topic
#1 JustD
JustD
    Starting My Mini Up
  • 4 posts
Posted 11 August 2013 - 03:13 AM
HI
Is there is switched live power lead in the boot I can piggyback from to trigger an amp "on"?
I'm putting an iPad Mini (through a preamp) in the dash and need to turn the amp (in the boot) on but was trying to avoid running another wire from the fusebox. It's a 1999 MPI Cooper.
Thoughts? Thanks in advance.
-David
#2 Yoda
Yoda
  • 1,958 posts
Posted 11 August 2013 - 05:54 AM
NO.
#3 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 11 August 2013 - 10:12 AM
Indicator is switched, but I wouldn't suggest using it for an ancillary because you could end up with no indicators if there's a short.
Edited by Skortchio, 11 August 2013 - 12:52 PM.
#4 Yoda
Yoda
  • 1,958 posts
Posted 11 August 2013 - 12:26 PM
DOH
#5 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 11 August 2013 - 12:31 PM
Just realised the comedy of my first point while in the bathroom, funny how things come to you like that.
Ignore the indicator option, mind you with modern music you might not even notice the amp switching of intermittently :P
Going to get a bit cup of coffee, haha.
But no, as Yoda says there's no feed in the boot although running a 14awg wire through the car wouldn't take long at all.
Edited by Skortchio, 11 August 2013 - 12:54 PM.
#6 Yoda
Yoda
  • 1,958 posts
Posted 11 August 2013 - 12:52 PM
OK, Shall i explain some simple electrical theory?
The supply to the washer bottle is only live when the washers are being used- first DOH
The switched live supply to the indicators will be on and off with the lamps- Second DOH
So if you want to use either of these live supplies, you have to either hold the washers on all the time or listen to every other word in a song by having the flashers on all the time.
DOH, silly me, if have the flashers on and push the washers in between the flashers being on, you could listen to the music all the time!
What was i thinking  >_<
#7 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 11 August 2013 - 12:54 PM
Realised it already, dude. ;D
#8 A-Cell
A-Cell
  • 1,610 posts
Posted 11 August 2013 - 01:12 PM
Ditto for the stop lamps! Tap the brake pedal for the music! ;-)
Could use the rear lights for a little night music.
Seriously run a cable is best idea.
#9 mk1monster
mk1monster
  • 287 posts
  • Local Club: Lowestoft Mini Club
Posted 11 August 2013 - 01:21 PM
Ffs you fools the answer is clear! There is a switched live. Just always drive in reverse and then you have a permanent connected switched live.
Simples.
Edited by mk1monster, 11 August 2013 - 01:22 PM.
#10 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 11 August 2013 - 01:24 PM
An alternative (what I have done) is to run a lightweight cable front to rear and use this to switch a relay in the boot. This means you will only have to run the heavier cable a short distance from the battery. (Correctly fused etc)
Hope this helps
Regards
Steve
#11 Yoda
Yoda
  • 1,958 posts
Posted 11 August 2013 - 01:35 PM
he dont need a heavy cable, its just a trigger for the amp he needs! No relay required.
#12 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 11 August 2013 - 02:00 PM
Switching relay will be in the amp - Missed that one - Sorry
#13 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 11 August 2013 - 07:37 PM
how about going off the electric fuel pump, if fitted in the boot?
#14 Yoda
Yoda
  • 1,958 posts
Posted 12 August 2013 - 03:48 AM
In theory yes it can be done, but with the extra load, and i know it is not much, i think we would see a new post from the OP wondering why his car wont start. that circuit is temperamental at the best of times. For the little effort it would take. a new wire from the ign controlled live at the fuse box would be best. A small cheat atthis stage could cause problems later on.
Do it right first time.
#15 JustD
JustD
    Starting My Mini Up
  • 4 posts
Posted 12 August 2013 - 01:32 PM
I already nixed the idea of the fuel pump wire - good idea, though.
I actually leaning towards the brake lights! Could be fun with music with a strong beat!
I'll pull a wire from the fuse box... Thanks!
-David
