Super Charger And Turbo?
27 replies to this topic
#1 beanboy450
beanboy450
  • 52 posts
Posted 11 August 2013 - 07:54 PM
Hi guys was just wondering is it possible to fit a turbo and a super charger to an A series??
#2 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Yes.
#3 Leics1275
Leics1275
  • 194 posts
Posted 11 August 2013 - 07:55 PM
It is, but it begs the question . . . Why?
#4 mini13
mini13
  • 3,811 posts
Posted 11 August 2013 - 08:06 PM
Space is your enemy,
to do this properly you'll need two intercoolers, one after each charger.
Also to make the most of it you need to run a big turbo, basically you use the charger to make the engine look like about a 2 litre, then boost that with a big turbo,
you have to be carefull though, as the boost increases quickly, ie 5 psi from the charger and 5 psi from the turbo does not equal 10psi!
#5 Tupers
Tupers
  • 4,156 posts
Posted 11 August 2013 - 08:09 PM
Is it possible yes, is it worth it no.
I'd imagine there's a lot of complex work that would need to go into making a twin charged system work effectively and even then I doubt it would out run a decent turbo only engine.
#6 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 11 August 2013 - 09:46 PM
If you can find one, Nissan did a Japan only special edition Micra that had both.........
#7 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 11 August 2013 - 09:55 PM
Someone did it on 16v mini club. They used a vectra throttle body as the switch over valve. It was in a brown clubman I think. Can't seem to find it at the moment unfortunately
#8 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 12 August 2013 - 08:42 AM
VW 1.4 TSI.
Normally run in series with the supercharger blowing through the turbo and then the turbo taking over as boost rises.
As above you multiply the pressure ratios and also the efficiencies - so 5 psi into 5psi = 12.5 psi ish at the manifold but at very high temp because of the double compression.
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 12 August 2013 - 08:52 AM
I wonder if a bi-turbo system would be easier?
#10 Andy!
Andy!
  • 481 posts
  • Local Club: N/A
Posted 12 August 2013 - 08:58 AM
Yeah, the march super turbo, MCM did a feature on it, bet they're hard to come by over here though!
#11 ac427
ac427
  • 679 posts
Posted 12 August 2013 - 01:40 PM
Too much heat i would say. An engine swap would be easier all round
#12 mini13
mini13
  • 3,811 posts
Posted 12 August 2013 - 04:43 PM
VW 1.4 TSI.
 yeas as above, 5 psi and 5 psi you'll see about 12psi at the engine, with 10 and 10 psi you's see in the order of 25 psi.
#13 mini13
mini13
  • 3,811 posts
Posted 12 August 2013 - 04:58 PM
Also I have read an interesting hypothisis that suggests that if run Big turbo into super into engine....
the supercharger will provide the gas flow to spool the big turbo, which will then see the turbo as a restriction, in which case you will then get a pressure drop across the supercharger.... and get a power output from the supercharger pulley.... and also a temperature drop across the super charger.
Note I use the word hypothesis!
#14 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 12 August 2013 - 11:56 PM
Uhm.....I think whoever wrote that hypothesis need to redo O level thermal engineering ology......:-)
#15 mini13
mini13
  • 3,811 posts
Posted 13 August 2013 - 04:53 PM
Indeed, did get me to thinking how much power per PSI you could get from a rootes blower if used as a "turbine"
