sweet man!
Harrys Zcars Vtec Mini
#31
Posted 08 January 2014 - 08:39 AM
#32
Posted 12 January 2014 - 05:03 PM
got it on its wheels temporarily
7541_10152149744859490_848869921_n.jpg 63.21K
48 downloads
7541_10152149744869490_775413670_n.jpg 63.22K
51 downloads
1526508_10152149744874490_1785592108_n.jpg 54.79K
30 downloads
1531824_10152149744864490_404147245_n.jpg 64.13K
34 downloads
#33
Posted 14 January 2014 - 11:39 AM
Looking Good
#34
Posted 15 January 2014 - 08:42 PM
#35
Posted 16 January 2014 - 05:50 PM
#36
Posted 16 February 2014 - 07:29 PM
just done the final (hopefully) order with zcars so there should be an update soon
#38
Posted 24 February 2014 - 03:35 PM
awesome man!
#39
Posted 24 February 2014 - 05:35 PM
Looking good.
#40
Posted 09 March 2014 - 04:15 PM
small update
got the pedal box mounts welded in, and welded a type r stem onto the iva steering coloum so i could use a type r boss i had, which fits my sparco wheel
once i am happy with everything i will spray the raised tunnel properly
exhaust is on and engine bay is nearly there, coolant in and fuel is in, ready for the engine start
just need to neaten everything up a bit
cable run through is on, used 20mm stuffing glands for brake/clutch/accelerator/spare and using 25mm for handbrake cables and gear change (waiting for the packet to come) thanks to cpt kirk for the advice via his thread (if you use heatshrik on the smaller cable you can then get a good seal if it isn't big enough
and the front is getting there, brake lines, coolant and fuel is in, just painted the bracket for the fuel filter and need to sort out the wiper motor still
plan for this week is to get it changing gear, handbrake working, rear brakes on, rear brake pipes on and a few other bits!
#41
Posted 10 March 2014 - 12:35 AM
Looking good.
#44
Posted 18 March 2014 - 07:18 AM
will try my best
#45
Posted 30 June 2014 - 09:30 PM
Great Build! Anything else?
