Alternator Without The Little Plug
9 replies to this topic
#1 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 25 August 2013 - 11:16 AM
hello,
ive coming to the last few wires of my new loom that need to find a good home :).
ive installed the big plug on my alternator but there`s also the small wire to plug, but my alternator doesn`t seem to have such plug ?
what shall i do with the cable ?
freaker
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 August 2013 - 12:15 PM
Picture of the alternator ? or this might resolve your problem and answer it http://www.theminifo...ons-spade-stud/
#3 freaker
freaker
  • 1,378 posts
Posted 25 August 2013 - 01:33 PM
 mine has the connections of an alternator up to 65amps, and thats connected correctly,
but i still have this little wire also coming out of the loom that if i`m right needs to be connected to the alternator ?
its a white/black whire
freaker
#4 GraemeC
GraemeC
  • 7,318 posts
Posted 25 August 2013 - 02:16 PM
That would normally go to the coil, not the alternator
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 August 2013 - 03:06 PM
As above.  Whit/black wires are used on the "low" side of the coil.  On negative earth cars they attach to the coil (-) terminal, the terminal that has a wire connected to the distributor.
You said this is a new loom.  There are likely to be (2) such wires.  One will be a short loop that goes from the distributor to coil (-) as I mentioned above.  The second wire (when fitted) is typically present for a tachometer connection.  You are likely to find another white/black wire emerging from the loom near the instrument cluster.  If you do not have a tach, leave both ends of the wire disconnected.  If you have a tach (factory or aftermarket) you can connect the engine bay end of the white/black to coil (-) and connect the other (instrument cluster) end of the wire to your tachometer's sense wire.
#6 freaker
freaker
  • 1,378 posts
Posted 25 August 2013 - 03:35 PM
i understand that, but on my loom,
where the distributor is, there is a white 12v after contact wire and 2 white/black wires together in on spade to go on the coil.
so as you are saying the white/black in the picture wich is leaving the loom later then the other 2 is a tacho wire ?
there also is one at the instrument pack...
freaker
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 25 August 2013 - 03:44 PM
On a car with points you normally have a small wire coming out of the distributor which plugs into a white/black wire in the loom.
If you already have the double white/black on one spade connected to the coil negative. then the wire you are showing should be the one the dizzy plugs into
#8 freaker
freaker
  • 1,378 posts
Posted 25 August 2013 - 03:52 PM
trying to follow here,
my dizzy only arrives next week :) its a powerspark one.
so i won`t need this one anymore if i`m right
freaker
#9 lrostoke
lrostoke
  • 6,923 posts
Posted 25 August 2013 - 03:56 PM
normally electronic dizzys like powerspark, have 2 wire red and black...you may find the black wire as the correct spade fitting to plug into that white/black terminal...if so use it.
#10 freaker
freaker
  • 1,378 posts
Posted 25 August 2013 - 04:36 PM
will see when it arrives friday :)
thanks already
freaker
