hi took the mini out for a spin yesterday. all was fine then 5 mins down the road it stops. turn the ignition and straight away i hear that the fuel pump isnt going. check fuses and all is fine. push it home. check that there is a current to the pump. there is. small current without ignition and then it jumps up with ignition on as it should i guess.
So its defo the pump thats buggerd?
is it spi or mpi tank i need for turbo?
anyone have one?
just a straight swap? pressure and such like will be the same due to regulator?
Thanks in advance!
Fuel pump
flameredturbo
, May 13 2006 08:08 PM
8 replies to this topic
Posted 13 May 2006 - 08:08 PM
Posted 13 May 2006 - 08:21 PM
beings what you have there is a bit of a "special", what is fitted now?
Posted 13 May 2006 - 08:23 PM
i cant rember if its a spi or mpi tank. what one do i need? its a turbo and has the return.
Posted 13 May 2006 - 09:02 PM
I gotta say I'm not sure of the differences between the two. judging by the price of the pumps on minispares, It'd probably be cheaper to whack a facet pump on there somehow. Have a read through the turbo section, I'm relatively sure it's been mentioned before.
Posted 14 May 2006 - 11:30 AM
All depends what boost you are running.
The MPI pump is a higher pressure than the SPI. Use the SPI pump up to 15psi boost and then the MPI up to 20psi boost but the SPi can cope to a degree.
MPi SPi physical tank is the the same, mountings, senders wiring all the same its only the pump thats different, hence the different part numpers.
With the regulator there sould be no need to adjust it if its set right in the first place, but well worth a check to be sure.
Posted 14 May 2006 - 05:41 PM
just another quick point. u can hear the pump when the tanks empty cant you? im gona feel real stupid if its just run out of gas!
Posted 14 May 2006 - 06:25 PM
Yes the pump will actualy get quite a bit noisier, but, at least on the injection cars the engine still runs but when you press the accelerator the engine hesitates and stalls
Posted 14 May 2006 - 06:27 PM
new tank it is then i guess.
Thanks for your help guys
Posted 17 May 2006 - 01:29 PM
sorry to sound dumb. so if i have a spi tank for example i can still fit an mpi pump? and vise versa? because i dont know what one it is fitted and im buying just a pump. all will be well?
