Just checked my plugs and realized it is all white at the tip n seems to he very lean
What can I do to make it run normal again ?
Spi Running Lean - Help
felixy69
, Aug 31 2013 10:22 PM
1 reply to this topic
Posted 31 August 2013 - 10:22 PM
Posted 31 August 2013 - 11:08 PM
First thing to check is the vacuum pipes, mainly the one to the ECU but all must be totally air tight, any minor gaps can give you all sorts of troubles. If they are OK then i would suggest checking there are no other leaks from the inlet manifold/throttle body. Is it noticeable when driving? If this dosen't have any effect then consult the SPI bible: http://www.theminifo...oint-injection/
