Diff Output Shaft Oil Seal Renewal
19 replies to this topic
#1 Ipod
Ipod
  • 2,024 posts
Posted 06 September 2013 - 04:51 PM
Can the diff output shaft oil seal be renewed without removing the output flange cover?
As iv got an oil leak were the driveshaft goes into the box
cheers
Ipod
#2 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 06 September 2013 - 05:35 PM
it is possible to change it in situ yes, but for the sake of undo-ing 4 or 5 bolts you can whip it off and do it on the bench, at teh same time you can make up (or buy) a gasket to go behind the output casting as that may have started to leak too.
i did just this on wednesday on a customers car!
#3 Ipod
Ipod
  • 2,024 posts
Posted 06 September 2013 - 06:14 PM
Thanks mate, i found out from the FB page that the special tool to knock the pot off might be needed too
#4 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 06 September 2013 - 06:43 PM
It's possible without the tool, however I have the minispares tool and makes the job a hell of a lot easier!
#5 Barman
Barman
  • 1,068 posts
Crow bar or other lever... make sure you don't damage the box or diff tho....
#6 Ipod
Ipod
  • 2,024 posts
Posted 06 September 2013 - 07:35 PM
anyone near Bexleyheath that i can borrow the tool for a day or 2 in a couple of weeks time....cheeky i know :whistling:
#7 IainStallard
IainStallard
  • 1,114 posts
Posted 06 September 2013 - 07:39 PM
I'm probably a bit far away!
When you do change it, don't forget to drain the oil otherwise you're in for a big surprise when all the oil pours out!
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 September 2013 - 07:40 PM
  Before you start check if the pot joint can be wobbled around in the housing.  Quite often the failure of this seal is due to wear in the bush allowing the joint to move.  If that's the case then replacing the seal will not stop the leak, a new bush will need to be fitted and reamed.
#9 Ipod
Ipod
  • 2,024 posts
Posted 06 September 2013 - 07:50 PM
Iain, not that far if your near box, as im over that way somtimes on my motorbike.
Dan, thanks for the info, i'll check that tomorrow
#10 IainStallard
IainStallard
  • 1,114 posts
Posted 06 September 2013 - 07:53 PM
PM'd :)
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 September 2013 - 07:56 PM
  The leak can also be due to the area of the joint that the lip of the seal bears against having worn down over the years and again in this case the new seal by itself may not cure it either.  Then it would be time for a new joint.
#12 Ipod
Ipod
  • 2,024 posts
Posted 06 September 2013 - 09:32 PM
is there a specific size reamer bit i need?
#13 tiger99
tiger99
  • 8,584 posts
Posted 07 September 2013 - 09:55 AM
It is very large, the diameter of the inner end of the pot joint, plus a very small running clearance. I don't have the exact size. It is not a job that you should think about doing at home, as it needs to be done on at least a pillar drill, maybe even a milling machine, so that the reamer is accurately perpendicular to the side cover. The bush is short in relation to its diameter. Doing it by hand is of no use at all, unless you are very lucky.
The several Rover manuals which I have don't give the necessary information, although they do show how to change the oil seals. Reaming these bushes would be well beyond the capabilities of most garages.
New side covers, with bushes already reamed, are about £60 each, and even at that price I think a new pair would be cheaper than the correct reamer.
I would strongly recommend asking your local engineering works to do it for you. Of course, if you have a machine shop at home, please disregard that. I would suggest measuring a new pot joint carefully on its running diameter and adding about 1 thou for clearance.
#14 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 September 2013 - 10:09 AM
New complete side covers are now NLA.
#15 Ipod
Ipod
  • 2,024 posts
Posted 07 September 2013 - 10:26 AM
Thanks tiger, i think i'll get new side covers
Dan, what does NLA mean?
