Hi,
failed MOT on this, anyone know how to fix this?
Kind regards
Oak RIchardson
Posted 10 September 2013 - 12:02 PM
Hi,
Kind regards
Oak RIchardson
Posted 10 September 2013 - 12:03 PM
I suspect it's an earthing issue!
You could clean up all the connections and add an earth for each light cluster!
Posted 10 September 2013 - 12:05 PM
crikey that was quick, I thought so, just wanted to check!
Posted 10 September 2013 - 12:06 PM
Posted 10 September 2013 - 12:07 PM
The wiring is poor to say the least!
If there was an earth for each cluster originally it would take less wire, but take more fitting!
I'm having a loom custom built with additional earths and less joints
Posted 12 September 2013 - 12:38 AM
That is indeed the correct fix, as I have said a few times. Actually, probably so many times that a few people have died of severe boredom.....
I just hate electrical things that have not been designed correctly, and the Mini wiring is in that category, although certain French vehicles were much worse. And, I don't like the earths at the front, which can be responsible for both headlights failing suddenly. On a dark night, that can kill.
