Fitted a new set of clocks today, albeit without the cover but the illumination isn't working, nor the left indicator for some reason, even after checking my bulbs! Anyway rather than taking it out I improvised and I quite like it..adds to the "classic" look ![]()
No Working Clock Bulbs...no Problem!
Posted 11 September 2013 - 09:44 PM
Posted 11 September 2013 - 10:17 PM
That is bodging like a boss there! XD
Posted 12 September 2013 - 12:07 PM
next to my clocks I have what I call 'the key'. It translates the readout of the speedo into actual miles per hour.
Posted 12 September 2013 - 12:15 PM
Check the inline fuses behind the carb/air filter as the instrument pack illumination is protected by one of these.
Posted 12 September 2013 - 12:28 PM
Posted 12 September 2013 - 12:33 PM
Actually, from memory I think the instrument pack shares it's fuse with the tail/side lights, so if they're OK, then it's probably not a blown fuse, still worth a look though.
Posted 12 September 2013 - 01:43 PM
This made me think about this picture:
Posted 12 September 2013 - 01:56 PM
What about glow sticks?
Posted 12 September 2013 - 02:13 PM
Posted 12 September 2013 - 10:23 PM
Have you checked the PCB on the back of the clocks?
I had this ages ago and it drove me mad, I eventually found it to be a break at the top of the PCB between the fuel/temp gauge and the tacho. God knows why they didn't make a solid mounting there! I soldered some wire across the broken part and didn't have a problem again.
Posted 12 September 2013 - 10:44 PM
One of mine has 2 panel light bulb holders reconnected this way.
The lack of solid is because the 2 pack instrument was common to both and the 3 pack just added the rev counter to the side, making the printed circuit a bit flimsy on the join!
Posted 12 September 2013 - 10:45 PM
Posted 12 September 2013 - 11:09 PM
Great guys thanks I'll make sure I check it out when I take them off...for now though I think the torch serves me well
haha thanks A-cell - it just needs some new batteries!
