Stereo Wiring
18 replies to this topic
#1 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 12 September 2013 - 07:17 PM
Hello guys and gals,
i have a 1994 sprite 1275 mini,
the car has NO radio wiring coming from the wiring loom, could i buy a DIY kit to fit a Universal plug like what the new units have?  what 'colours' of wire do i need to splice into?!
all help appreciated
many thanks
Edited by cal844, 12 September 2013 - 07:18 PM.
#2 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 12 September 2013 - 10:27 PM
Not sure if you can buy anysort of plug, but if you go into halfords and get a iso plug to bear wires and just run a constant live and a switched live to it which you can find at the fuse box and then you just need a ground, and the rest of the wires are speakers
#3 rikSTAR
rikSTAR
  • 128 posts
Posted 12 September 2013 - 10:44 PM
I've not seen an 'off the shelf' kit to do it, but mine is wired on the fuse box, one permanent live (memory) on the radio loom, and the (battery +) on the radio loom I've wired to the fuse that becomes live on the second click of the key, then ground obviously goes to ground
#4 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 14 September 2013 - 10:47 AM
there is NO wiring in the loom for the radio  which is wierd so annoying! i'll have a look on internet
Edited by cal844, 14 September 2013 - 10:51 AM.
#5 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 16 September 2013 - 01:13 PM
a little progress... Kernow sent me the Haynes manual (cheers Dave), so i can try to work out where my wiring has been used, i suspect it has been used for the Smiths timepiece, which actually works :ohno: , so now i just need to connect my battery to find out which wire does what... wiring, i hate you!
#6 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 16 September 2013 - 02:43 PM
I make a "plug and play" powere loom for a mini with the standard ISO connector for £15 posted.
I can also do the speaker loom for £10 (2 speakers in rear) or £15 for 4 speakers (2 front & 2 rear)
PM me if you are interested.
David
Edited by Wilson1330, 16 September 2013 - 02:44 PM.
#7 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 16 September 2013 - 03:07 PM
David
i will wait and check my wiring (i think the previous owner has wired the smiths timepiece into the radio lives.) i will pm you if needed
thanks  again folks
#8 freshairmini
freshairmini
  • 1,718 posts
Posted 17 September 2013 - 11:56 AM
The radio wiring is very, very simple.
Permanent live from the fusebox.
Switched live from the fusebox.
Earth to good earth point. That's it (apart from speaker wiring but that is even simper!).
You can use a male and female iso block for easy removal. I found this useful as my windscreen leaked so was often removing the Hu to try and save it!
Here is the manual page that shows the fusebox terminals for live and switched. Sorry for the quality of the picture, there used to be a good one on t'interent but its gone! either-way should help you.
#9 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 17 September 2013 - 12:19 PM
Dont forget to fuse things - never run wires from the fusebox without independant fuses :(
#10 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 17 September 2013 - 01:34 PM
thanks very much!
#11 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 17 September 2013 - 01:37 PM
i think i have found some of my wiring, i will have a look once i finish building the rest of the car!
#12 freshairmini
freshairmini
  • 1,718 posts
Posted 18 September 2013 - 12:15 PM
 There are fuses in the fuse box... lol
If the wire shorts after the fuse box the fuse will blow.
#13 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 18 September 2013 - 12:30 PM
Its neither safe nor recommended to add further strain on the fuses in situ. Any new systems should be taken from the left hand side of the fuse box and fused independently.
If you take a permanent live from the right side to the HU you are allowing the chance for 25A / 35A to pass down a wire designed for 10A.
Please think about advise before handing it out. I build looms and am a wiring trader on here. Not just a TMF+ Member.
#14 freshairmini
freshairmini
  • 1,718 posts
Posted 18 September 2013 - 02:25 PM
Correct me if I'm wrong, if the wire draws more current than the wire can take the fuse will blow anyway (because the fuse is rated to the wire) so its protected away, so it wont even be able to draw 25.35A? So what difference does it make?
especially since radios draw very little power anyway and many, many people have wired it like that, seen as that's how it would have come standard if it had a radio (feed taken from the right side of the FB)...
#15 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 19 September 2013 - 04:52 PM
i'm changing the fuse box to a modern blade type anyway, couldnt i just run a perm. live from the battery?!
