Stereo Wiring
18 replies to this topic
#16 Carlos W
Carlos W
  • 10,114 posts
Posted 19 September 2013 - 05:00 PM
i'm changing the fuse box to a modern blade type anyway, couldnt i just run a perm. live from the battery?!
No!
The radio needs a fused permanent live, and a switched live from the ignition.
Mini wiring isn't fantastic to start with, overloading it can cause fire
#17 Carlos W
Carlos W
  • 10,114 posts
Posted 19 September 2013 - 05:13 PM
Dont forget to fuse things - never run wires from the fusebox without independant fuses :(
 There are fuses in the fuse box... lol
If the wire shorts after the fuse box the fuse will blow.
Its neither safe nor recommended to add further strain on the fuses in situ. Any new systems should be taken from the left hand side of the fuse box and fused independently.
If you take a permanent live from the right side to the HU you are allowing the chance for 25A / 35A to pass down a wire designed for 10A.
Please think about advise before handing it out. I build looms and am a wiring trader on here. Not just a TMF+ Member.
Correct me if I'm wrong, if the wire draws more current than the wire can take the fuse will blow anyway (because the fuse is rated to the wire) so its protected away, so it wont even be able to draw 25.35A? So what difference does it make?
especially since radios draw very little power anyway and many, many people have wired it like that, seen as that's how it would have come standard if it had a radio (feed taken from the right side of the FB)...
If you run a 25 amp fuse, connected to a wire rated a 10 amps, the unit could draw 22 amps for example due to a fault.
This could cause the wire, and ultimately the car to catch fire.
Just because lots of people have done it doesn't make it right.
#18 freshairmini
freshairmini
  • 1,718 posts
Posted 23 September 2013 - 03:21 PM
I understand that, but just out of curiosity, why would they put in a 10amp wire fused at 25amps, would that not make the fuse useless as the wire could have melted/caught on fire already?
#19 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 23 September 2013 - 04:11 PM
hmmm my car has a
white(perm live?) on top fuse RH side terminal
blue to 2nd fuse RH side terminal
and
red to bottom fuse RH side terminal,
i believe they are for the clock etc however i think my radio wiring might be hidden in the 'loom' the previous owner made!!
