Hi guys, require a small amount of help if you don't mind.
I recently took the clutch and flywheel of my 1982 austin mini 1340cc to replace the crank seal as it was leaking. Now I've reassembled it and have no parts left over. I can't engage any gear on the move and when I take my foot off the clutch it reduces the engine rpm slightly and a faint whining sound occurs. When being rolled in either direction and left to come to a stop it rocks forward and backward slightly and the clutch seems to bite really harshly when moving. Ive taken it off a few times now and still can't see what the problem is, if any of you guys could help with some advise that would be great. It's a veto clutch by the way.
Thanks for your time.
Kind regards, Matt.
No replies to this topic
Also tagged with one or more of these keywords: engine, brakes
Mini Technical Sections →
Problems, Questions and Technical →
Excessive Fuel Pressure - Regulator Or New Pump?Started by daddums , 20 Aug 2025 ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
