Hi, I've been having trouble figuring out why my engine's always running too rich.
Watching an AC Dodd video recently put me onto the idea that the fuel pump might be supplying the carb with fuel at too high a pressure.
I bought a cheap fuel pressure gauge off ebay and attached it with a t-piece before the carb inlet and it's reading just over 6 psi. I understand it should be around 1.5-3.6 psi.
Questions:
1. Am I right in thinking that could explain why I haven't been able to lean off the air fuel mixture?
2. AC Dodd suggests fitting a fuel filter with built in pressure regulator (FPR004 on MiniSpares I think). I've read on here that others are skeptical about a pressure regulator and suggest replacing the pump with an electric one which supplies fuel at the correct pressure (such as the ECCO 1LM12). Cost either way seems similar. What are the advantages and disadvantages of each option?
1991 Mini City E
998cc engine with 12g940 head, hs4 carb, maniflow exhaust
Currently has mechanical fuel pump which looks like MiniSpares AZX1818MS
Thanks in advance!
