Air Filter For Weber 45
Posted 15 September 2013 - 08:45 PM
Posted 15 September 2013 - 08:53 PM
ITGs have a good report and easier to fit depending on the space remaining
Posted 15 September 2013 - 08:58 PM
Posted 15 September 2013 - 09:23 PM
Posted 15 September 2013 - 09:48 PM
Posted 16 September 2013 - 07:14 AM
Posted 16 September 2013 - 10:48 AM
Bloody hell med £200 for an itg set up I think I may just stick a big k&n on
Yes but you get all of this:
Posted 16 September 2013 - 09:28 PM
As i stated in my previous post i have an HIF 44 which has the correct ITG filter and stubstack that was purchased from MED for £90.00.Bloody hell med £200 for an itg set up I think I may just stick a big k&n on
I do not know how much the ITG filter setup is for a Weber 45 but i would assume it is more than a single carb setup as you will need a larger filter media area and two stub/ram pipes for the Weber 45.
I originally had a 45 on my 1380 and in comparison the HIF 44 performs just about the same from around 3000rpm upto 5500rpm, above that the Weber just tips the scales but consumes far more fuel in doing so.
Posted 16 September 2013 - 09:54 PM
And yeah I know you get all that but still steep for a air filter considering a k&n probs does the same
Posted 16 September 2013 - 10:35 PM
Itg made a difference over the k&n on my hif :)
Posted 17 September 2013 - 07:13 AM
I'm sure there are other filters just as good but cheaper
Posted 17 September 2013 - 08:29 AM
i use the k&n like this one -
on my weber 40 dcoe. Fits lovely and is recommended in the a-series bible although itg weren't around then.
Posted 17 September 2013 - 09:17 AM
If it was me, I'd use the ITG, you've already gone for the more expensive option of the weber over a hif44, and the rest of the build is top spec, so why not going for a top spec air filter?
Posted 17 September 2013 - 09:24 AM
Posted 17 September 2013 - 11:34 AM
The ITG filter, would that fit on with the short maniflow manifold without any bulkhead work?
