Usa Hot Temperature
8 replies to this topic
#1 zuluaga63
zuluaga63
  • 113 posts
Posted 17 September 2013 - 09:11 PM
i Just moved ack to the usa after a long year in france where i saw a mini in ireland and bought it.
the mini is almost here it will be here next week in miami florida. i wanted to know do i have to change anything like the thermostat the temperature here is 30c to 36c
can i get some recommendations to what should i modify.
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 17 September 2013 - 09:24 PM
Aluminium rad, thermostat blanking sleeve and a good well looked after water system should see you through:P
You may not have to get an aluminium rad, see what it's like with a thermostat blanking sleeve on first and a cleaned overhauled water system:P. Then if it's still hot an ally rad should fix it;)
#3 zuluaga63
zuluaga63
  • 113 posts
Posted 17 September 2013 - 09:54 PM
allright thank you .
#4 The Principal
The Principal
  • 763 posts
Posted 18 September 2013 - 06:26 AM
I upgraded to an alloy rad and didnt notice a huge difference however when I fitted an addditional electrical fan then yes that made a big improvement. I'd suggest before changing the rad for half the money try an additional fan betweeen the rad and the inner wing or fit a six bladed fan which is even cheaper but will make more noise and sap a tiny amount of engine power. http://www.minispare...px|Back to shop
#5 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 18 September 2013 - 07:57 AM
I think you'll find that aluminium isn't as effective at transferring heat as brass,so changing to an aluminium rad isn't the best thing to do.  Fitting a MiniSpares Super 2-Core is much better.
#6 Barman
Barman
  • 1,068 posts
Posted 18 September 2013 - 08:04 AM
I live in Cyprus with similar temperatures (actually is was 45 last weekend)...
I have the two-core radiator from MiniSpares and the 6-blade 'hot climate' fan...
I have no problems with overheating at all... the fan is a little noisy but it does seem to move a huge amount of air through the radiator!
#7 firstforward
firstforward
  • 824 posts
+1 copper core
#8 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 18 September 2013 - 02:13 PM
I have a SPI with aircon in Florida and I have not had any problems while driving. However, it has the auxiliary electric fan and that makes a big difference if idling for long or in stop and go traffic. I don't see any need to do anything special unless your cooling system is in need of service, i.e. new thermostat, new water pump, flushing sytem etc.
#9 freshairmini
freshairmini
  • 1,718 posts
Posted 18 September 2013 - 02:35 PM
+1
