Second Heater Valve Blown. Which Is Best?
20 replies to this topic
#16 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 18 September 2013 - 10:46 AM
I'm sure stranger things have been done before.
Seriously though. Thanks for your help.
Edited by jime17, 18 September 2013 - 10:47 AM.
#17 1984mini25
1984mini25
  • 8,785 posts
Posted 18 September 2013 - 11:36 AM
 Having had a stuck open heater valve on a boiling hot summers day, I found that it turns the classic mini sauna into even more of an oven, (even with blower off and the windows open). But I suppose you could always remove the valve and see how you got on, and then fit an inline valve at a later stage if required.
On the plus side, having no heater valve does mean a constant year round flow of coolant through the matrix, meaning your matrix is less likely to collect debris from your cooling system and then corrode/leak over the summer months.
I bought a mini years back were the heater cable had seized with the heater tap valve stuck in the full on position, as you say it was like a sauna (at least I new the heater worked) in the summer until I replaced the cable.
so far I haven't has any problems with the £2 second hand genuine tap from the autojumbles, as I prefer most of the time to have the heater tap somewhere between hot and cold, to keep some flow through the heater.
#18 tiger99
tiger99
  • 8,584 posts
Posted 18 September 2013 - 11:34 PM
Are the valves failing because the system pressure is too high, because of a very simple problem, the wrong radiator cap being fitted?
If it is not that, I guess we have just found yet another useless, badly made counterfeit part from a certain far eastern country. This is getting very tedious, to say the least, but at least it does not have the safety implications of another recent one, wheel bearings.
#19 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 19 September 2013 - 08:37 AM
I'm pretty sure that it's a case of a batch of low quality parts, as opposed to a symptom of an underlying problem, dodgy heater taps seem to be a bit of a common theme here of late.
#20 1984mini25
1984mini25
  • 8,785 posts
Posted 19 September 2013 - 11:13 AM
I have known of some radiator caps, although being the correct 15psi for a mini (and most other cars) that fit too tightly onto the radiator to be able to release any excess pressures, but it does appear to be a batch of faulty heater valves.
#21 ucchockey
ucchockey
  • 158 posts
Posted 19 September 2013 - 10:59 PM
My radiator cap is rather old and has been fine for years but I guess it could be duff. The two failed valves were both new. I have ordered a take off with no valve to eradicate the problem. I never use the'cold' option anyway. I'm just going to find a novel and amusing use for the spare knob in the car. Could have a secret compartment that opens when you pull it or a little flip up message in the window or something. Lol
