Why Do Minis Rust So Much!
64 replies to this topic
#1 MiniGrin
MiniGrin
  • 499 posts
  • Local Club: Loud 'N' Lairy MOC (Sheffield)
Posted 20 September 2013 - 01:36 PM
My mini had pretty much all new body panels put on by its last owner shortly before he sold it. I was looking through the photos he had taken at different stages and still cannot believe how rusty it was! Why are minis so bad for the rust? For example a similarly aged Rover/MG seems to still be reletivly rust free still (mine is a 98). And also will the heritage panels used to replace the rusted ones be much more durable than the originals (as technology on rustproofing and rust prevention has advanced)?
#2 seancv1
seancv1
  • 187 posts
Posted 20 September 2013 - 01:54 PM
Modern cars are e coated so a special primer reaches every normally un reachable nook and cranny.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 September 2013 - 01:57 PM
I read a lot of the MK5 shells were stord outside until finished and therefore the UK weather did its bit, which they said is why so many of the newer Coopers and others are worse thern the MK4s and back.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 20 September 2013 - 02:06 PM
For the later minis there is a distinct lack of paint between flanges etc so this is their biggest downfall. Also lack of decent rustproofing does not help either.
Now to restored cars. There are issues between pattern and Heritage panels. For example the pattern panels have a very poor coating on them that does need to be removed before painting. If not then this will cause issues. Also have the new panels been seam sealed before painting etc.
Has weld thru primer been used when attaching the new panels. This plays a big part in a decent resto.
#5 IainNeon91
IainNeon91
  • 1,287 posts
Posted 20 September 2013 - 02:07 PM
They also have a lot of places which just hold moisture and water
#6 jaydee
jaydee
  • 8,565 posts
Posted 20 September 2013 - 02:25 PM
You clearly never had an MK1-2 fiesta or an old fiat :P
#7 Richey
Richey
  • 314 posts
Posted 20 September 2013 - 02:40 PM
Does anyone know if specific models were better than others? I drive a Sidewalk, and it's stood up really well over the years. Other Sidewalk owners I spoken to have said the same. Mine has been stored outside most of its life, and is doing pretty well on the rust front...
#8 firstforward
firstforward
  • 824 posts
Posted 20 September 2013 - 02:53 PM
Add Lancia's to that.
#9 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 20 September 2013 - 04:41 PM
My Sidewalk has stood up pretty well too, however there have been a few I've seen that have been completely attacked by the weather
#10 mab01uk
mab01uk
  • 12,469 posts
Posted 20 September 2013 - 05:09 PM
Modern cars have plastic wheel arch liners and floor undertrays as well as galvanised steel in vunerable areas, wax injected cavities to allow long rust warranties to be offered. Also all body panel seams are bonded together with a special sealant applied by robots which adds strength and waterproofs the spot welded seams. None of this was or could easily be applied to the late 1950's design of the original Mini and would have further added to cost.
You can however fit plastic arch liners and wax inject sills and box sections yourself.
INNER WHEEL ARCH LINERS (ONE FRONT PAIR ONLY)
http://www.minispare...ty=pb&pid=37262
Edited by mab01uk, 20 September 2013 - 05:10 PM.
#11 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 20 September 2013 - 05:13 PM
The later MPI cars (like yours) were at a point when they were cutting corners at Rover. Paint cost money, so they used as little as possible. I have seen pictures of the area under the rear seats with NO paint. These cars are often in a worse state than cars 10 years older.
#12 SecretSugar
SecretSugar
    Sweet!
  • 508 posts
Because they crave attention and TLC!
#13 Mk1Dave
Mk1Dave
  • 519 posts
Or a 10 year old Mercedes. Most of them have no boot floors left
#14 Daz1968
Daz1968
  • 2,058 posts
Posted 20 September 2013 - 05:29 PM
Minis unfortunately have a lot of water traps and construction techniques are outdated compared to other cars mentioned. Add in the fact it is assembled before painting so no paint under hinges and external seams, also the lack of front under wing protectors and rear subframe with even more water traps then all this adds up to a car that will rust easily, it don't stop us wanting one though.
#15 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 20 September 2013 - 05:32 PM
Mini 30s seem as bad if not worse than MPis. Every one I see is either rotten or restored.
