Mysterious Electrical Gremlins Stealing My Power...free Of Charge
electrical
5 replies to this topic
#1 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 23 September 2013 - 06:03 PM
I've had this problem on two occasions now. I believe it all started when a loose connection to the alternator regulator caused it to overcharge, and subsequently boiled the battery. Fixed this problem, battery stayed as it was as it seemed ok. Went to start the car the next day after finishing work...nothing. The battery was dead. So with a new battery fitted (with the alternator problem now rectified) the car has been trouble free and starts on the key first time.
However, upon leaving college today (or trying to whichever way you look at it) the battery was once again dead. I don't think anything was left on, so I can only imagine that the alternator was playing up again and was constantly back feeding? Had to bump start it, but was fine all the way home. My volt meter read around 14.2v when running.
The only thing I can say is that for the past couple of mornings, it has run very lumpy (like a one-legged Mr Blobby).
#2 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 23 September 2013 - 06:58 PM
Years ago I had a Mini that acted a bit like this, it turned out to be the Positive battery cable shorting to the body, it was usually worse when it rained!
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 September 2013 - 07:56 PM
Put a amp meter on the main battery + cable and see if you have a discharge showing with the ignition off and doors closed, if so remove the plug from the back of the alternator and redo the test, if no curent discharge showing then its the diode pack, if its still showing a discharge come back with more info on the type of car/year
Edited by KernowCooper, 23 September 2013 - 07:58 PM.
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 23 September 2013 - 10:18 PM
It's ok now. Well actually there was never a problem...Basically there is a tiny switch concealed in the car, fitted by a previous owner. Ever since I got this car, throughout the restoration I had been flicking this switch to see if it did anything. I assumed it wasn't connected to anything due to the soldered wires hanging next to it. Miraculously, every time I flicked the switch, I flicked it back. In the college car park my friend found this switch and thought, 'Ooh, what does this do?' Hence my car wouldn't start on the key.
Thanks for your suggestions anyway, I'm sure they would have helped if a problem actually existed. >_<
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 September 2013 - 10:56 PM
Your sorted now with your new found inhibiter switch ;D
#6 zerobelow
zerobelow
  • 136 posts
Posted 24 September 2013 - 01:39 AM
http://foldoc.org/Magic+Switch+Story
