Exhaust hangers.
Posted 16 May 2006 - 03:38 PM
Any clues?
cheers
mark
Posted 16 May 2006 - 03:40 PM
have you got a pic
Posted 16 May 2006 - 03:44 PM
Posted 16 May 2006 - 03:49 PM
Posted 16 May 2006 - 04:57 PM
does the one at the rear bolt into the same holes that would be used to mount the other typr exhaust fitting?
Posted 16 May 2006 - 05:07 PM
The other hanger bolts up inside the front facing edge of the rear LH side of the subframe near where the rubber doughnut sits.
Sorry if this sounds coplicated but i cant draw it too quickly.
It took me a while to figure out but they fit fine.
PS both brackets should be different, if you have both the same that is a problem
Posted 16 May 2006 - 05:56 PM
Posted 16 May 2006 - 05:58 PM
Posted 16 May 2006 - 06:00 PM
I have those type hangers on mine. one fits the the front end of the subframe where the usual rubber block fixes the two captive bolts.
this helps, thanks, any chance of a pic?
i have got both hangers, the pics was just a guide
cheers.
mark
Posted 16 May 2006 - 06:51 PM
i will try and find a pic of mine
here is a pic.
Mine has the exhaust hangers already welded on but that is the rough position that you want it to be.
The arrow points to where I think you should bolt on your hanger.
Posted 17 May 2006 - 02:55 PM
Anyone got a pic of one on the car? Pretty Peas
mark.
Posted 18 May 2006 - 10:08 PM
Arrow on photo above is right and bracket for rear mounts inside the ushape of the back subframe cross piece. the photo shows how the hanger should sit. The other bracket bolts top centre as shown on photo to existing holes in subframe.
Posted 18 May 2006 - 10:31 PM
