right im doing a flip front and i was wondering if i need solid subframe mounts im not sure which ones i just remember reading it somewhere so i thought i would ask. anyone??
subframe mounts
davexdavexdave
, May 16 2006 10:52 PM
3 replies to this topic
Posted 16 May 2006 - 10:52 PM
Posted 16 May 2006 - 10:57 PM
yep! I got mine from minispares, but most places do them. You'll need just the rears and uppers (and not the front teardrops) and a set of bracebars. (the bracebars "replace" the front mounts.)
Posted 17 May 2006 - 06:43 AM
Best ones to go for are the solid alloy upper subframe mounts that go either side of the turret bolts. It's up to you whether you also go for solid lower mounts, there is a risk of the floor cracking where they mount as it's not particularly strong.
I always use normal mounts at the bottom and alloy at the top...
Posted 18 May 2006 - 02:19 PM
cool i thought the floor might crack so i'll do the same. where do i get alloy top mounts??
