![Photo](https://www.theminiforum.co.uk/forums/uploads/profile/photo-thumb-54360.jpg?_r=0)
92 Mini Fitting A 1098 Engine
Posted 30 September 2013 - 08:11 AM
Matt
Posted 30 September 2013 - 11:03 AM
Should be easy, but you currently have a pre engaged starter, verto clutch and unleaded head and an A+ engine (which the 1098 may not be - there were some A+'s about in 1098 if memory serves but most likely to be A series) the only tricky bit I can see is perhaps having to rewire the starter motor circuit to contend with an inertia starter and swap the head over. Much depends whether the 1098 has all it's ancilliaries... if it does life is much easier, without having to swap bits over that, may not be intended for that engine - e.g dizzy...... The swap is much easier if changing liek for like i.e A+ to A+...nothing is impossible though - just a little more involved...
How on earth... lack of oil aside, have you managed to blow up a 998?????
