How can i identify which carb i have, I know it is an SU (suprise suprise) and i have a feeling that it is a HIF 44, but would like to know for certain.
http://i12.ebayimg.c...f6/02_12_sb.JPG is an image of it from above which probably doesn't help sadly it is the only shot i have of it at the moment.
cheers
Dan
Carburettor Identification
danccooke
, May 17 2006 07:42 PM
5 replies to this topic
Posted 17 May 2006 - 07:42 PM
Posted 17 May 2006 - 07:53 PM
definately a HIF, but it could be of multiple varieties. You'll need the throat size to be sure.
Posted 18 May 2006 - 12:09 PM
Well it looks identical to the standard HIF44 as fitted to my 1990 Mainstream Mini Cooper 1.3 if that helps?
Posted 18 May 2006 - 12:14 PM
it is definitely a 1 3/4" so i am guessing then it is defo at HIF44
Cheers for the help.
just waiting for me registration code now from WinSU so i can work out what needle i need.
Posted 18 May 2006 - 12:26 PM
aaah, if you have it in yur hand, the check the number on the little shiny tab, an x-ref it on burlen.co.uk. that should tell you exactly what it is!
Posted 18 May 2006 - 12:29 PM
Well the only way to do that effectively is to get it set up on a rolling road. Mind you I haven't as yet, but I did fit a slighly richer needle (after fitting a Stage One kit and K&N cone type filter like the one in that picture) and it's BFY, where as the original needle was BDP, that's if my memory serves me correct?
