I was adjusting the contacts under the cap of the dizzy and was then adjusting the timing through rotation of the dizzy. The dizzy was then locked off with the plate (at least i thought it was), and when I went to turn the key, the dizzy popped out of its locating hole. Now I cant get the dizzy back in the hole, only goes so far in. Its as if the cog that it locates in has come out in a way, any ideas anyone?? Thanks
Distributor Jumped Out Whilst Engine Turning Over
Posted 06 October 2013 - 07:48 PM
Posted 06 October 2013 - 07:52 PM
Hope not but has the dizzy drive shaft dropped down into the gearbox..........
Edited by richw911, 06 October 2013 - 07:52 PM.
Posted 06 October 2013 - 08:03 PM
nah the whole dizzy in still intact, just wont let me locate her back in the hole fully home!
Posted 06 October 2013 - 08:15 PM
Not the dizzi shaft - the cam to dizzi shaft - in the block - It can jam against the crank & cause mayhem
take a pic - don't turn the engine over
you can put a bolt in it to realign it
(or you may be fine , if dizzy goes in and locates on the shaft)
fingers crossed - as it can be a pig
Edited by sledgehammer, 06 October 2013 - 08:16 PM.
Posted 06 October 2013 - 08:36 PM
have you tried turning the rotor arm 180 degrees, the slot is offset it only locates one way
Posted 12 October 2013 - 02:21 PM
Bump to the top.
Any updates on the dizzy drive gear position?
