Removing Inner Cv Joint From Driveshaft.
7 replies to this topic
#1 Stu.
Stu.
  • 912 posts
Posted 13 October 2013 - 11:42 AM
Hi,
I am trying to remove the inner CV joint from the driveshaft. Haynes says you should strike it with a flat bar to free it, but Ive been hitting it pretty damn hard and it wont budge. Am I doing something wrong ??
#2 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 13 October 2013 - 11:53 AM
Have you tried heating the CV?
#3 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 13 October 2013 - 11:58 AM
If you have already tried hitting it off then try knocking it back onto the shaft first. Then hold it so you can give it a good sharp hit. It will either release in one sharp hit or won't release at all.
There is a bit of a knack to it but if you get it right then the circlip pops into its groove and releases the joint. If you just keep hitting it then the circlip stays in place and holds the join onto the shaft.
#4 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 13 October 2013 - 12:17 PM
i did mine recently,
ive put it in a vice, so it didn`t move.
and with a flat chisel and a reasonable hammer a good wak and it was moving, i also was expecting it not to move :)
freaker
#5 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 13 October 2013 - 01:50 PM
If all else fails.......
http://www.theminifo...-stuck-to-axle/
#6 Stu.
Stu.
  • 912 posts
Posted 13 October 2013 - 06:04 PM
Well that was fun. I tried heating it, hitting it, hitting it lots more, swearing at it then thretening it but none of that worked, so then I resorted to getting out the Dremel and cutting it into pieces to get it of the shaft, so thanks for the link aboveVery greatful.
I was careful not to cut into the driveshaft splines, but was worried I would as it's difficult to gauge depth :errr: but it seems I was ok though !
The extent of corrosion to the mating faces of the driveshaft, circlip and CV joint knuckle shows why it wouldnt budge I guess, but at least I know for next time.
I'll clean up the shaft spline so it's ready to take the new joint, as I dont think I can re-use the old one now do you ;D
Something else learnt today :D
Thank you for all your advice guys :thumbsup:
#7 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 13 October 2013 - 08:04 PM
Great to know it worked for you! Make sure to use some good grease (preferably synthetic) on the splines before assembly. Anti-seize (graphite) or copper grease might create more corrosion problems with the moisture.
#8 Stu.
Stu.
  • 912 posts
Posted 13 October 2013 - 08:26 PM
I was wondering if lack of suitable grease to the splines before assembly was what caused the seizure. There was certainly no sign of any grease when I cut off the CV joint !
If I remember correctly I think the Haynes manual suggest using graphite grease, so I'll avoid that then and use some synthetic.
Thanks for your help. Very greatful to you !
