Breathers.
Posted 18 May 2006 - 07:14 PM
ok now then breather for engines. i know they not really the greatest things in the world unless your highly tuning the engine. i also know that you shouldn't add one to the carb as it may cause things to break or go boom.
you see (sorry about this being a bit all over the place but stay with me) i was having a play with my engine and i find that with the oil cap off it idels nicer. SO what i wanted to know is, Is it a bad idea to add and engine breather to the top of the rocker cover. i mean add a hole to the cover then add a little breather to allow some more air in. i know that the oil filler cap is an air filter but in my little world more is normaly better. so is it a stroke of genius or is it a very very bad idea.
also how the cheese do you get a car to run nice without the breather pipe on the carb. on my carb the engine stalls out if you stop the flow (took the pipe off and coved the hole with my finger) so how do people with that bit blocked up make it run smooth.
and alloy rocker covers do they have breather if not then you get basical the same thing as my above statment. how do you get the car to run smooth without it stalling.
bit of a random selection of question but i don't know these things so i have to ask.
Posted 18 May 2006 - 09:52 PM
You dont NEED to connect it to the carb but if you dont then you need to blank the input to the carb.
Yes a highly tuned engine will benefit from extra breathers....such as the rocker cover but a standard engine does not need them.
Make sure your current breather is not blocked and then you need to get the engine tuned......it should not need the filler cap removed to idle smoothly.
Posted 18 May 2006 - 11:09 PM
so then why dose my car basicaly stall with the air inlet blocked. if the carb dosn't need it then why won't the car keep running. or is it beacuse the mix go super rich as i changed the mixture. so its running slightly rich with the extra inlet blocked it must go super rich then.
so my idea for an engine breather inlet on the rocker covers not a good idea then. ooow.
edit
oh yeah....errrmm.....no money so no pro tuning or RR for me. lol. being a student rocks!
Posted 19 May 2006 - 09:12 AM
Posted 19 May 2006 - 09:53 AM
and how dose a 5.50 breather come anywere close to the £30 odd for a rolling road.
Posted 19 May 2006 - 10:01 AM
To me, you shouldn't be putting in breathers to get an engine to idle correctly, that should be done with carb tuning and have the timing set correctly. The standard breather system should be fine for most engines needs.
Posted 19 May 2006 - 10:18 AM
I thought the outcome of your last post was that you were going to get the correct exhaust and manifolds for your engine, selling the ones you have to fund it?
Erm....wasn't that someone else?
Posted 19 May 2006 - 10:24 AM
also even if i did sell my old stock Exhaust looking on flebay i woun't get much more than say £20 squid well short of the 100+ neede for a stage 1. all this thread was is a few quetions and ideas i had. which now look like they were not as good as i thought. oh well. saved myself 5.50 odd.
Posted 19 May 2006 - 10:30 AM
Still my statement about getting the carb running right instead of adding a breather still stands.
Yea, I think you've taken the best choice. I think I was getting you mixed up with someone else with the Stage 1 kit.well it was just an idea as i always think more is better. so more air into the engine the better it is. althoguht not always the best ideas for somethings just the way i am. , getting a new oil cap breather as mine needs replaceing i orded it....yesterday now from mini spares as well as some bushes i needed.
Posted 19 May 2006 - 10:35 AM
Posted 19 May 2006 - 05:48 PM
Posted 19 May 2006 - 06:14 PM
Edited by Dan, 19 May 2006 - 06:15 PM.
Posted 19 May 2006 - 06:16 PM
Posted 19 May 2006 - 07:32 PM
<<snip>>
<<snip>>
never been replaced since it came out of the factory. anywho Dan yeah i will have to do that. just got to tweek it back a bit. i listed to the engine and see how it sounds while i;m doing it.
cheers all. my questions and querys once again answered.
