How can i wire in my electronic dizzy i've got on my 1275cc metro block into my minis wiring loom? I've pulled out the wires from the metro loom but i dont have a clue where to start on the mini wirring loom.
Cheers, CAU998
Electronic Dizzy
CAU998
, May 19 2006 11:03 AM
3 replies to this topic
Posted 19 May 2006 - 11:03 AM
Posted 19 May 2006 - 11:49 AM
which elec dizzy are we talking about? a standard lucas metro item? If so, the two wires go to the two terminals on the coil. simple.
However, there has been talk of the system being ballasted or non-ballasted the last couple of days, and now I'm unsure as to which it is!
Posted 19 May 2006 - 09:30 PM
Need the plug to fit the electronic dizzy. This will have two wires coming from it, white/yellow and white/black. Connect the white/yellow to the coil '+' (and if your exisiting wiring is ballast ignition (should see a wire that says 'ballast' under the grime) you will need a new wire from the "live when ign on" fuse).
You do need the electronic coil, that and the electonic dizzy all run at 12V.
Then connect the white/black wire to the coil '-' and that's it!
Or if you dont have the plug you can order new ones from me
Posted 21 May 2006 - 05:26 PM
Thanks, ill make a note of this
