Clutch
engine
4 replies to this topic
#1 Mini special
Mini special
  • 11 posts
  • Local Club: Skins
Posted 17 October 2013 - 11:54 PM
My 1100 is crunching into gear sometimes think it's more when warm just had engine rebuilt could clutch have air in system ??engine running beautiful just struggling with first and second when standing still then seems to be ok for 5min then it will happen again reverse is also crunching the clutch isn't slipping when driving and sometimes makes me think I'm going mad cause I've tried to show people and it doesn't happen any ideas on what's going on want to go minifair2 this weekend but don't want to end up on a recovery truck!!!!any advice please lads
#2 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 18 October 2013 - 05:01 AM
If you car has the long clutch arm it could just needs some adjustment.
You can also test the Hydrolics by ensuring that the arms moves 0.5 of an inch when fully depressed.
#3 Kt1966
Kt1966
  • 232 posts
Posted 18 October 2013 - 07:45 AM
I had something similar with my Special too.
Bizarrely, when I got it there was no return spring attached. Put it on and it starts to crunch...
Have left it off for the time being until someone who knows more than me can have a look...
#4 tiger99
tiger99
  • 8,584 posts
Posted 18 October 2013 - 08:49 AM
Running without the spring is harmful, so you should sort it out asap.
First get a friend to operate the pedal, and confirm with a ruler that from pedal up to fully down, the movement at the slave cylinder is 0.55", and it holds its position as long as the clutch is held down.
Then, before you refit the spring, hold the lever away from the slave cylinder, and adjust the stop bolt for 0.5mm clearance, You can reduce it to 0.4mm if necessary. Once that is done, you can fit the spring, and get your friend to hold the pedal down again, while you loosen the locknut in the centre of the "wok", adjust the stop nut untill it is just in contact with the casing, tighten it one flat more, and do up the locknut. Then give it a try.
If there is still a problem, report back and whoever is along first will take you through some more checks.
#5 Mini special
Mini special
  • 11 posts
  • Local Club: Skins
Posted 18 October 2013 - 08:23 PM
Thanks boys il be on it in the morning il let you know what happens
