Thinking Of Reverting To Back To Distributor
28 replies to this topic
#1 minivanman8
minivanman8
    Previously known as minimadandy.
  • 426 posts
Posted 19 October 2013 - 10:44 PM
I can't make my megajolt talk to my laptop and I hate the fact that it's the modern technology screwing up my mini so I'm thinking of going back to a distributor.
Question is, will I distributor work with the advance curve? Would a metro turbo unit do?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 October 2013 - 10:55 PM
Whats the spec of your engine ? obviously a distributor cant be mapped by the degree but I see your reason if your having trouble
#3 minivanman8
minivanman8
  • 426 posts
Posted 19 October 2013 - 11:00 PM
Supercharged 1293, 18cc pistons, fairly standard head, sw5 cam, hiff 44 carb, turbo clutch, standard 'box
#4 Zik
Zik
  • 80 posts
Posted 19 October 2013 - 11:12 PM
Does the guy who produces the megajolt offer any support or warranty? If you do get rid of it and are looking to sell it I would be interested in buying it off you.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 October 2013 - 11:47 PM
Their are some here running a distributor but speak to H&H Ignitions they will do a advance curve for you
#6 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 20 October 2013 - 10:35 AM
I doubt the Metro Turbo dizzy will be anywhere near correct for your spec. You can get a dizzy tailored to suit your engine, but first you need to know the advance curve your engine requires.
Have you asked for help on the Megasquirt forum ? You must be pretty desperate to want to go back to a clockwork ignition.
Phil.
#7 minivanman8
minivanman8
  • 426 posts
Posted 20 October 2013 - 10:46 AM
I've posted on auto sport labs but am still awaiting reply.
I'm getting very desperate. I can't use the van with the ignition as far out as it is and can't adjust it as I can't talk to the mega jolt box.
I don't want to be spending more money on it though as it's already cost a fortune!
#8 minivanman8
minivanman8
  • 426 posts
Posted 20 October 2013 - 10:47 AM
I don't have a clue what advance curve I need!
#9 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 20 October 2013 - 11:21 AM
Have you installed the usb properly, is it using the correct com port? I was desperate last year with mine, it turns out that the lead out of the mj unit into the usb was broken inside. Very cheap fix, if you have it all installed properly otherwise
#10 minivanman8
minivanman8
  • 426 posts
Posted 20 October 2013 - 11:24 AM
Driver software came with the USB-serial cable. I've tried 4 different USB-serial cables. 2 different laptops. Com port is matched between laptop and mj programme.
See here
http://www.autosport...p?p=20020#20020
#11 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 20 October 2013 - 02:24 PM
Sounds like what i had. Providing all of yours is installed properly? Try changing the lead from the mj to the usb, worked for me...
#12 minivanman8
minivanman8
  • 426 posts
Posted 20 October 2013 - 02:37 PM
If you're talking about the USB-serial converter cable (http://www.atozstars...p?idproduct=424) then I have tried 4 different ones
#13 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 20 October 2013 - 02:59 PM
Could still be the cable. We use them to link between a laptop and our motor controller on the electric cars we race. There are at least three varieties on how they are wired up. We have one that works but had a nightmare trying to get a spare. In the end I took it all down to a local computer shop and through their stock until we found one that worked.
#14 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 20 October 2013 - 07:31 PM
I purchsed all of my parts from trigger wheels. At least you know they are likely to work out of the packet.
#15 minivanman8
minivanman8
  • 426 posts
Posted 20 October 2013 - 07:36 PM
This setup was already installed when I bought the van. The cable that came with it wasn't even recognised by either laptop.
