I would like to relocate the rear brake lines, from the top of the radius arm. Where is the best mounting point?
61' Morris Mini
Posted 21 October 2013 - 10:16 PM
61' Morris Mini
Posted 22 October 2013 - 06:33 AM
i just did mine, used the minispares braided setup that takes the hard and rubber line away great for a low car, just cable tie or use a rubber "p"clip to secure
Posted 22 October 2013 - 06:02 PM
Posted 22 October 2013 - 09:48 PM
Yea, spot on. I'm riding pretty low and I'm in the process of changeing over to ss lines, thought now would be a good time to move that mount. For some reason I thought the connection between the hard and flexi line had to be hard mounted.
Posted 22 October 2013 - 09:49 PM
I don't quite understand the question, dry cars have the metal and flexi pipe running along top of the arm, hydro cars have it going below the arm, why do you need to move it?
Sorry forgot to mention, my car has been converted to dry suspension, rear subframe and arms have been replace. Cheers.
Edited by Ratkiller, 14 November 2013 - 11:20 PM.
Posted 23 October 2013 - 08:17 AM
the flexi hose now goes from the wheel cylinder right up the arm and over to the subframe hard line
Posted 23 October 2013 - 04:49 PM
Posted 24 October 2013 - 07:16 AM
yes it replaces the hard and rubber flexi thats shown in your 1st pic , so its a braided hose thats got that banjo fitting ont the wheel cylinder and then the other end is the male end thats like on the end of that rubber hose, so your killing 2 birds with 1 stone , replacing shiit rubber hose and also the hard line that can get crushed on low minis
Edited by johnnyblaze, 24 October 2013 - 07:17 AM.
Posted 25 October 2013 - 04:10 PM
Great thanks!!!!
