i have recently put on a stage 2 head form mor speed on my mini but when i went 2 put in the new temp sender in 2 the head it was 2 long on the thread does anyone no of a shorter 1 (i.e was there a shorter 1 on the metro)
many thanks
temperature sender
simon1275
, May 20 2006 09:48 AM
10 replies to this topic
Posted 20 May 2006 - 09:48 AM
Posted 20 May 2006 - 10:07 AM
why not just pack it out with some washers. i mean if you can't find a stubby temp sensor.
Posted 20 May 2006 - 10:10 AM
yeah that was my other option just dont look as good allthough could paint it in with the head so it blends in
i will take the sender 2 the L2B tomorrow and ask the advice of the trade stands see if they can help
Posted 20 May 2006 - 11:57 AM
define too long. The thread is tapered which does leave a few threads showing.
Posted 20 May 2006 - 12:36 PM
well if not washer then make a nice spacer. somthing out of alu then polish it up. add a little bit of bright work.
Posted 20 May 2006 - 12:51 PM
its 2 long by about 5 - 6 mm
Posted 20 May 2006 - 12:54 PM
does it tighten properly? just leaves about 5mm of thread visible? Sound OK if it does.....
Posted 20 May 2006 - 12:56 PM
yes it makes a complete seal i think i will have 2 make a spacer out brass and polish it or ali and paint it
Posted 20 May 2006 - 12:58 PM
if you make a spacer and its even slightly too long, it'll destroy the seal and leave your engine leaking. too short and it defeats the point of the spacer....
Posted 20 May 2006 - 01:02 PM
unless i use a rubber 1 but it wont look as good
Posted 20 May 2006 - 03:38 PM
Tapered thread sensor in a tapered thread hole will seal with a bit of PTFE tape, that is how it works.
Use any sort of spacer to bottom the sensor on the nut part is incorrect and not nescisiary (sp)
Don't look to fix a problem that isn't there. That is unless you have the wrong sensor to start, then that is your problem and easily fixed with the correct item. There were only two types fitted to the mini with a carb and i doubt you will have the earlier one.
I realy dont think you have any problem. I think thats what Pikey is trying to say.
