Garys K20 Zcar
44 replies to this topic
#31 minithekid
minithekid
  • 113 posts
Posted 02 April 2014 - 07:53 PM
tried the seats in the car today. I used some 2x4 alloy box section for the floor
mounts that bolt to the cobra seat mounts!   I cut two 4inch slots in the box so they are adjustable
by loosening the bolts that go through the floor for the driver side only!  they work a treat!
#32 minithekid
minithekid
  • 113 posts
Posted 13 June 2014 - 03:43 PM
just a few more pictures on with the dreaded wiring!
Edited by minithekid, 13 June 2014 - 03:59 PM.
#33 GeorgeMini
GeorgeMini
  • 172 posts
Posted 13 June 2014 - 06:42 PM
nice work! keep it up :)
#34 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 16 June 2014 - 03:20 PM
Top work....
#35 minithekid
minithekid
  • 113 posts
Posted 01 July 2014 - 06:41 AM
thanks lads for the kind words!...sometimes it makes me get my finger out!!
  got my kirkey seats delivered just on making the sub frames made the drivers side with runners. not much to report getting a couple of jobs done going to be repainting some of the inside inner front bulk head and floor due to a crap choice in the 1st painter 8(   electrsions coming next week to get it wired up!  I have tied the seat frame into the roll cage bolts at the rear and into the box section! here's a few pictures of my seat runners and sub frame. ...........and spot the garage ghost!!
Edited by minithekid, 01 July 2014 - 06:47 AM.
#36 minithekid
minithekid
  • 113 posts
Posted 13 August 2014 - 07:05 AM
I was never happy with the floor even after the so called painter finished it!
   so three weeks of rubbing down building up the primer and top coat
      and only using shaky cans I am finally happy with it! :shifty:
#37 miniQ
miniQ
  • 497 posts
Posted 14 August 2014 - 12:09 AM
What didn't you like about the floor? aren't you going to carpet it?
Looks less glossy/shiny.
Edited by miniQ, 14 August 2014 - 12:10 AM.
#38 minithekid
minithekid
  • 113 posts
Posted 14 August 2014 - 04:46 PM
it wasn't up to a good standard! ...I am going to carpet it but knowing what's under it pezzed me off!
       less shiny!!  I didn't drown it in lacquer and hide any marks like the first painter did I just painted it properly :proud:
                                             look what's come in the post today!...
Edited by minithekid, 14 August 2014 - 04:52 PM.
#39 ralfchoueiri
ralfchoueiri
  • 21 posts
Posted 03 September 2014 - 06:46 PM
is it okay to install the raised tunnel at an early stage? isn't it hard later for the brake and gear cables?
#40 minithekid
minithekid
  • 113 posts
Posted 03 September 2014 - 07:21 PM
is it okay to install the raised tunnel at an early stage? isn't it hard later for the brake and gear cabl you need it in to paint the inside!
you need it welding in before you paint the inside. I cut a hole in the dash end of the tunnel so I could fit wiring through into the dash area take a look at cpt kirk supercharged k20 build, Andy has made my build so much easier we all have him to thank!....thanks Andy kirk
Edited by minithekid, 03 September 2014 - 07:23 PM.
#41 ralfchoueiri
ralfchoueiri
  • 21 posts
Posted 03 September 2014 - 07:58 PM
I will check it out right away, thanks dude :)
#42 cptkirk
cptkirk
  • 1,799 posts
Posted 04 September 2014 - 06:30 AM
My Pleasure......
#43 minithekid
minithekid
  • 113 posts
Posted 08 February 2015 - 06:15 PM
 a bit of a update all the wiring is done and the car starts  just had the mini down to zcars to have the caster camber wheel aliment done next is wheel arches and to make a fire wall for the engine bay...
Edited by minithekid, 08 February 2015 - 06:22 PM.
#44 andream88
andream88
  • 169 posts
Posted 17 April 2015 - 01:10 PM
Hey Gary, any news on this?
#45 IainNeon91
IainNeon91
  • 1,288 posts
Posted 25 August 2026 - 09:55 PM
Stumbled across this thread, after 10 years since selling my last mini, i've ended up with this one! Thought some people might like to see the car completed
https://flic.kr/s/aHBqjD3nGs
Edited by IainNeon91, 25 August 2026 - 09:57 PM.
