my indicators will not flash and the light inside the car will come on and not flash either, my hazzard switch is very tempemental also, if i replace the hazzard switch will this cure my indicators? or will it be a flashing unit?
thanks for your time ali
my indicators
alilee
, May 21 2006 03:02 PM
3 replies to this topic
Posted 21 May 2006 - 03:02 PM
Posted 21 May 2006 - 10:45 PM
unit
to my nolidge the hazard has a different circut
Posted 22 May 2006 - 09:59 AM
The indicators are routed through the hazard switch, so you might find a new one does do the trick.
When mine started playing up it turned out to be both that and the flasher unit!
Dismantled and cleaned the switch (do this in a brightly lit kitchen not a dark garage as it is inclined to spring little bits everywhere) and cleaned up the contacts on the flasher unit and all good.
Posted 22 May 2006 - 01:43 PM
That will be the indicator flasher unit which, depending on the year of your car, should be situated behind the dash, just to the right of the steering column (if you are looking towards the windscreen).
