Read the last couple of months of practical classics. They have been doing some in depth research on exactly this problem. The outcome was that all the major manufacturers (who responded) considered the SRS parts to be safe to last the 'lifetime' of the car, even when that contradicts an expiry date on said parts. They also considered the problem of using parts from scrappers and found no problem as long as the parts weren't from crashed cars. Perhaps time to buy a few spares from some rusty cars?
That's useful. I think you are right - reading the Gov't and VOSA guidelines on this one - I understand if it is a standard fitment at manufacture then it has to be there and working. No exceptions. Maybe time to stock up on spares, as you say.
Bottom line, if you remove the srs indication and the airbag then they are not testable.
Interesting, I don't think airbags are mandatory, the implication of that would be that they are. I could understand the SRS rule as assurance against malfunction, but removing the airbag would achieve that - better as it would be absolute assurance that an aged airbag wouldn't disintergrate in your face, even if activated correctly.
Hmmm.....wish that were the case but I believe that when an SRS system is fitted as standard, as manufacturers specification, it must in place and working.(End of...) However, I feel it may vary between testing stations as a tester looks at it and says " Mini - no airbag then". Not all MOT testers are Mastermind specialists on "The Mini 1959 -2001" I guess we'll see, given time
