My Window Wipers And Fan Heat Are Playing Up! Help Please?
electrical
5 replies to this topic
#1 Benstocker96
Benstocker96
    Starting My Mini Up
  • 3 posts
Posted 25 November 2013 - 10:53 AM
Hi could any one give me some help please?
I have a Austin mini 850 1980 and this morning went out to my car this morning and when I started the car I tried to use my wipers and my fan heater and neither would work but all of my other electrics worked.
After I have let the car run for a little while about 5, 10 minutes the heater all of a sudden started to blow air, and then I tried the wipers and they worked to. Could anyone explain why this happened?
My dad reckons I could be a relay or lose wiring?
Thanks Ben
#2 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 25 November 2013 - 11:06 AM
They run on the same fuse. Possibly a dodgy connection.
#3 Benstocker96
Benstocker96
    Starting My Mini Up
  • 3 posts
Posted 25 November 2013 - 11:14 AM
Ok I will have a look at that when I get home, thank you :)
#4 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 25 November 2013 - 12:49 PM
turn on the wipers and heater, then have a play with the RH connections on the fuse box, it might also be a build up of dirt etc so i'd remove the fusebox (write down all wiring colours and locations)  and give all the contact areas a clean(remember to clean the rear of the fusebox and the area around the fusebox location)
hope this helps
#5 finch661
finch661
  • 2,340 posts
Posted 25 November 2013 - 01:06 PM
 /quote]
Ghosts?
Edited by finch661, 25 November 2013 - 01:06 PM.
#6 Benstocker96
Benstocker96
    Starting My Mini Up
  • 3 posts
Posted 26 November 2013 - 10:37 AM
Thanks for the help guys, car seem to be ok and no issues now. Everything worked fine last night and this morning :proud:
I think the ghost may have left now :P
