Why Is My Door Fouling On The Hinge Panel?
7 replies to this topic
#1 carlburt78
carlburt78
  • 239 posts
Posted 25 November 2013 - 03:47 PM
i put the A-post in put the door back on it fits in the hole nice but when you open it it gets stuck on the bit where the A-panel goes, do you think its the replacement panel at fault?
#2 R1mini
R1mini
  • 1,387 posts
Posted 25 November 2013 - 04:28 PM
I would first check the door is fitting correctly across the back edge, space that gap correctly then look at the gap at the front.
I had to trim that panel in the picture in order for the door to open and close properly, then I had to trim it again to allow the A panel to fit properly
David
#3 carlburt78
carlburt78
  • 239 posts
Posted 25 November 2013 - 04:37 PM
When you say back edge do you mean the edge where the door handle is? If so it fits fine against that edge
#4 mini13
mini13
  • 3,811 posts
Posted 25 November 2013 - 05:35 PM
these come with extra material, you need to get to door gap right round the rest of the door, then trim it back to suit to get the correct A panel clearance.
a flap disc and a steady hand works ok.
#5 carlburt78
carlburt78
  • 239 posts
Posted 25 November 2013 - 06:02 PM
thank god for that i was ready to scrap it today,ive really struggled with the A-post ive had to redo it 3 times as to welds being weak and then having it in the wrong position i think i should have started with something easier for my first restoration attempt thanks
#6 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 25 November 2013 - 06:08 PM
Like above it may need to be cut down a bit, don't forget the a-panel wraps around it so make it roughly the same curve.
If there is a big gap at the back don't worry too much, get/make some shims to go between the hinge and a-post to bring it back.
#7 R1mini
R1mini
  • 1,387 posts
Posted 25 November 2013 - 06:13 PM
Yes, basically make sure the door fits properly, then trim as required where the door is catching
David
#8 carlburt78
carlburt78
  • 239 posts
Posted 25 November 2013 - 06:22 PM
I havnt got any A panels yet and im going to attempt the inner and out sills next so i think i will come back to it another time,im just glad i havnt got to do the A-post again,ive made every mistake possible on this side! Atleast ive learnt how not to do it when i do the other
