Ball Joint Failure When Driving Resulting In A Crash
Posted 28 November 2013 - 10:38 AM
Approaching a bend I had a sudden loss of breaking and steering which put me up an embankment and into a hedge.
Thanks the everyone at barnsley mini club who rallied round to help.
From a line on the road it looks like a ball joint has gone and cause the caliper to move with the disc and take out the tie bar.
The question id like to ask is in that situation, what is the most appropriate reaction? Ie, gear down, brake harder, handbrake etc.
I know there isnt a definitive answer but if a discussion and a thread can help anyone in the same situation not be a passenger I think it's worthy.
Posted 28 November 2013 - 10:44 AM
Posted 28 November 2013 - 10:54 AM
Why do ball joints break like this? Is it because the ball becomes solid in the cup resulting in the shaft snapping? Is this from lack of greasing? One would expect them to get looser & sloppier rather than tighten up (assuming correct maintenance is performed). Glad you're OK Burgerdale....
Posted 28 November 2013 - 10:56 AM
Off the brakes and little steering movements if it is a straight road.
If you are approaching a bend you need to get speed off the best you can and aim at the softest landing point.
Can break from lack of maintainance or overtighening
Edited by mk3 Cooper S, 28 November 2013 - 11:09 AM.
Posted 28 November 2013 - 11:05 AM
this happened to my old man last year, at 70mph on a duel carriage way!
the actual hub gave way - the threaded part snapped off inside the ball joint.
Posted 28 November 2013 - 11:12 AM
It's not the first, perhaps we can have some close up photos or even arrange to have it analysed? Is its origins known?
As for the best course of action, chances are there's very little you can do. Steering towards the damaged side and coasting to halt would be the best way to keep it from ploughing into the ground, but that's unlikely to be practical unless you're luck enough to be in the middle of a deserted car park. You're also unlikely to be aware there's a problem until you're digging a groove in tarmac, you could try braking but there's a fair chance the hydraulics have already been ripped off.
Welshdan,
Can you say with any certainty that was the cause or just an effect of the remnants hitting the road at speed?
Posted 28 November 2013 - 11:13 AM
Happened to me in the 80's, Analysis determined thet it had been overtightened
Posted 28 November 2013 - 11:16 AM
glad your ok, that's the main thing.
I'd be interested to know the history of the ball joint, lots of discussion on them be over tight, poor quality, lapping etc. etc.
Have they been replaced recently?
Posted 28 November 2013 - 11:30 AM
The appropriate action is to crap yourself, inspect the damage, then find out who supplied/makes the ball joint.
Posted 28 November 2013 - 12:01 PM
There is a long groove in the road that is a straight line to where I hit the hedge.
Its starts where there is a change of surface.
We had to drive through an area with new and the harshest square edged speed bumps ive been over in a long time that day too. I suspect that had something to do with it. They were too close together to fir through and even though I slowed to a crawl they were still harsh.
Posted 28 November 2013 - 12:04 PM
Thank god for roll cages.
Posted 28 November 2013 - 12:20 PM
i double checked the tightness of the balljoints, when i buy my cars and also before an MOT when i take the wheels off and wash the arches etc and have a good look at all components
Posted 28 November 2013 - 12:23 PM
When you look at the state of the roads it isn't a surprise
I wish they would fill the pot holes with the speed bumps
as to the fault - maintenance / poor quality parts / too tight / too loose , there are many reasons
that area of the car does take a battering , with heavy shock loading
In a perfect world ...
If that happened to me I would use the brakes (to light the brake lights) , yank on the hand brake (should be un affected)
and try to steer with the remaining good wheel to a soft spot , where there is lots of soft fluffy things
In reality ...
stomp on the partly deflated brake pedal (assuming brake pipe gone), forget anything wise and safety related , & cry 'MUMMY'
glad your ok
Edited by sledgehammer, 28 November 2013 - 12:26 PM.
Posted 28 November 2013 - 12:31 PM
Pics of the broken bits?
Posted 28 November 2013 - 12:44 PM
