A New Starting Issues... Spi
Posted 28 November 2013 - 01:25 PM
Engine removed running and refitted.
Good spark,
Fuel pump primes and you can see it spraying into the throttle body,
Checked all relays with my Crypton reader and all test fine.
Car tries to start but just won't run.
Help please? Never had this problem before! lol
Posted 28 November 2013 - 01:28 PM
Mate join the club check out my turning over but not starting thread, I would suggest as I've been doing at the moment is clean up all your earths then clean the connections on the starter motor and coil. Get a voltmeter see what your battery is doing also check this at the starter and coil ends. This is the point i'm at, I did get mine started after charging the battery however the day after mine was back to square one, hope you get your sorted too
Edited by Bratby, 28 November 2013 - 01:28 PM.
Posted 28 November 2013 - 01:40 PM
I've got mine on jump leads to my shogun to eliminate any battery issues. Adding an extra earth has improved the turn over but nothing else :/
Ta
Posted 28 November 2013 - 04:25 PM
Any ideas?
Posted 28 November 2013 - 05:37 PM
Sounds like timing...... Has the dizzy been removed? PLug leads on the wrong way round perhaps?
Posted 28 November 2013 - 06:44 PM
