Cams 276 Vs 286 Vs 286 Scatter
16 replies to this topic
#16 pickuptruck1994
pickuptruck1994
  • 366 posts
  • Local Club: Weston Mini Muckers
Posted 05 December 2013 - 10:11 PM
Jordan
JUst double check what diff you have in the MG Metro gearbox. Bill Richards recently rebuilt my MG Metro engine and gearbox and I'm sure he said they had a 3.7 dif as standard as they ran on 12 inch wheels.He changed it for a 3.44 and it gave better cruising speeds and I'm still on 10 inch wheels. I'm no expert so it's not gospel but I would just double check if you're going to that effort.
that interesting i will be doing bulk rings and other worn parts on it so will check when i have got it all apart cheers for pointing that out.
regards
jordan
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 05 December 2013 - 10:46 PM
I actually run a 276 in my 1330, its a stage 4 head balanced bottom end with a centre main strap, Stg 2 Maniflow LCB with 1 3/4 side exit single box system, Aldon Yellow witha HIF44 with stub stack, Its slightly lumpy at idle but useable everywhere and half the secret is getting the carb calibrated on the correct needle which to get it right will be a modified one.
276 good cam in my opinion
