Brakes!
brakes
#1 Frobertson623
Frobertson623
  • 3 posts
Posted 06 December 2013 - 03:36 PM
Hi, My break pedal goes to the floor, it happened over night.  I've tried bleeding it but their is hardly any flow from the bleed nipples.
What do i do!?!?
#2 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 06 December 2013 - 04:08 PM
check there isnt any leaks anywhere, a hose may have split or corroded. have you tried  all the bleed nipples. you may find 2 are better than the other two, the two worse ones may be on the broken half of the system. if its all as bad then just look round the whole system for leaks. If there arnt any then check your wheel cylinders to see if they have seized or are leaking. i didnt see mine were leaking till i removed the drum and pumped the pedal. if they are ok then masted cylinder / servo may be at fault. silly question but has the pin fallen out the pedal? it may be your pedal isnt connected, doubtful but worth a look
#3 waddle
waddle
  • 536 posts
Posted 06 December 2013 - 04:12 PM
have a look to see if you have lost brake fluid, then you will know if you have a leak or some other fault
#4 Cooperman
Cooperman
  • 23,041 posts
Posted 06 December 2013 - 06:51 PM
1.  Don't drive the car.
2. Check the brake fluid level
3. If the fluid is low take of the wheels and see where the fluid has leaked from. e.g. rear wheel cylinder, cylinder, etc.
4. Replace the defective component(s).
5. Bleed system with new fluid.
6. If the fluid is not low suspect the master cylinder and change it.
