Oil Change
21 replies to this topic
#16 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 13 December 2013 - 08:12 PM
Worth replacing the sump plug washer when doing the oil change
#17 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 13 December 2013 - 08:14 PM
And don't forget to clean the magnet.
#18 surfblue
surfblue
  • 1,827 posts
Posted 13 December 2013 - 08:51 PM
to be on the safe side im looking at buying Evans coolant which has a boiling point of 180, expensive, but im willing to put the money into it to keep her happy!
Thats a waterless coolant, the whole system must be completely drained and flushed before using.
#19 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 13 December 2013 - 09:00 PM
Then if you spring a leak its an expensive loss. I am happy to keep my original cooling system which works perfect when kept in good condition.
#20 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 13 December 2013 - 09:48 PM
also just because the boiling point is 180 doesnt stop the temperature getting to 180 lol coolant boils at something like 110-120 i think, by that point you would have already switched it off i would hope
#21 1984mini25
1984mini25
  • 8,785 posts
Posted 13 December 2013 - 10:07 PM
surprised no ones picked up on the point that before doing an oil change on a mini or any other car, to go for a drive the get the oil/engine up to temperature so the oil is thinner. Obviously to change the coolant/antifreeze the engine does need to be cold to prevent burns from boiling hot coolant.
#22 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 14 December 2013 - 08:58 PM
And don't overtighten the sump plug, It's easy to strip the thread.
