Zcars Big Brake Set Up Issue
2 replies to this topic
#1 GeorgeMini
GeorgeMini
  • 172 posts
Posted 15 December 2013 - 05:12 PM
Hi all,
Now, as simple as this seems.. i simply can not for the life of me work out whats wrong.
The red anodised piece bolts onto the upright.. and the calliper bolts onto the red piece. Simple! But there is a massive aligning problem so I cant bolt the calliper onto the red piece. Why is this?
I have tried swapping the callipers over but they are identical, as are the red pieces....
Is this is manufacturing fault?
I have also tried fitting the red piece from the other side of the upright, but then the bolts that hold the disk on fowl against it so that cant be right.
save me!
cheers
#2 R1mini
R1mini
  • 1,385 posts
Posted 15 December 2013 - 05:22 PM
The disc needs to be reversed, you should also swap them side to side to get the venting holes in the correct orientation I think
David
Edited by R1mini, 15 December 2013 - 05:26 PM.
#3 GeorgeMini
GeorgeMini
  • 172 posts
Posted 15 December 2013 - 05:29 PM
new it was something simple like that, cheers mate
