i have a stadard 998 sky but am fitting an lcb manifold and new inlet manifold but im unsure of if anyone makes a seperate inlet manifold to fit the card thats on the engine (HS2 i think) can anyone help please
Help!!
Bradley
, May 25 2006 05:44 PM
5 replies to this topic
Posted 25 May 2006 - 05:44 PM
Posted 25 May 2006 - 06:50 PM
on a 998 you want a cooper free flow exhaust manifold not a LCB
as for the inlet yes you can get them most stage 1 kits would come with one
Posted 25 May 2006 - 07:06 PM
yeah as bungle says you want a freeflow as the lcb dosen't give enought back pressure. it works but if your squeesing evey last bit of power out of the engine the an freeflow is what you want. (cheers dan. hee hee)
anywho manifolds here from mini spares. you'll also more than likey need a bit of pipe as most manifolds for a single carb are water heated.....why i have no idea.
http://www.minispare...spx?ccid=110102
Posted 26 May 2006 - 03:20 PM
hi
thanks for that unfortuantly i have already purchased the LCB manifold... will it still fit and run?
Posted 26 May 2006 - 03:29 PM
oh yeah. still fit and run. no probs. just if you wanted the most performace you want a freeflow one. the LCB will be fine.
Posted 26 May 2006 - 03:33 PM
cheers thanks for your help
