Exploded Diagram Or Photo Of Pwda Brake Valve Fam7821 Needed Please
18 replies to this topic
#16 Ethel
  • 26,028 posts
Posted 19 December 2013 - 01:05 PM
Load sensing valves are in essence adjustable, I don't see any difference as long as it's not fitted as a driver's control. The subframe valve will work, the FAM valve offers the advantage that it uses front line pressure to reduce the rear: no front brakes = no reduction in rear brake efficiency, so you could stop a little sooner in the event of a failure (the rear is still likely to lock up). I reckon an inertia valve is a better solution all round.
#17 lindsay_palmer
lindsay_palmer
    Just On Tickover
  • 9 posts
Posted 21 December 2013 - 12:22 AM
Thanks Ethel. I'm looking into recovering the photos of when I dismantled the FAM 7821 valve. If I get the photo back I'll post it for others to see
#18 Ethel
  • 26,028 posts
Posted 21 December 2013 - 01:17 AM
It's not a uniquely Mini part, I'm sure I've seen an Aussie (Moke?) forum with a topic on servicing one with a generic O ring. I'm not sure I'd recommend it unless you can be sure of the seal's suitability.
Ta dah!
#19 lindsay_palmer
lindsay_palmer
    Just On Tickover
  • 9 posts
Posted 21 December 2013 - 11:33 AM
Ethel. That's exactly what I was after. Thank you very much.
